Where Should My RPMs Be At?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elk assassin, Nov 3, 2013.
  1. Nov 3, 2013 at 9:05 AM
    elk assassin
    elk assassin [OP] Active Member
    Ohio CIty, Colorado
    1993 Lifted SR5
    Fellas-
    Complete newbie but would someone help me understand how to figure out what my RPMs should be at various speeds and in various gears? I think I saw there is a formula to figure this out but I can't find it and probably wouldn't be able to figure out how to use it if I could. The Tacoma in question is a 2011 Access Cab, v6, TRD Off-Road 4x4 with a 5-Speed Manual transmission. It has 265's on 16 inch rims if that matters. Any help you could give me would be greatly appreciated. Doug
  2. Nov 3, 2013 at 9:16 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    u have a 5 speed manual v6?
    calculators can be used to help on the RPM, but we need to know if u have a 5sp auto, or a 6sp manual..... Im looking up info still
  3. Nov 3, 2013 at 9:22 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  4. Nov 3, 2013 at 9:29 AM
    elk assassin
    Ohio CIty, Colorado
    1993 Lifted SR5
    Justus-
    Thanks for the reply. In the link you sent me for the formula on how to calculate RPM's, it asks for the transmission ratio. Do you know where I can find that for my particular vehicle?
  5. Nov 3, 2013 at 9:34 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  6. Nov 3, 2013 at 9:37 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  7. Nov 3, 2013 at 9:46 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    images_1d8860f6f1ee92a14c9d30b1d7756af755d00bcb.jpg Drive it and let us know.
  8. Nov 3, 2013 at 10:02 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I thought the manual would tell you? Just need practice OP, that's how we all learned. You'll find grinding gears is the worst noise ever.
  9. Nov 3, 2013 at 11:31 AM
    elk assassin
    Ohio CIty, Colorado
    1993 Lifted SR5
    Fellas-
    Thanks for the help. Last question and then I'll go try to get some data and see if I have reason for concern. For a 5-sp manual transmission there is 8 different possible transmissions listed. What is the easiest way to find which one I have, look in the manual or look for a part number on the transmission itself? Thanks a bunch. Doug
  10. Nov 3, 2013 at 11:34 AM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    You don't have a 5 speed manual with a V6 on a second gen. You have a 6 speed manual option or a 5 speed automatic.
    As far as when to shift and cruise, it just depends on what you're doing. Just practice and go with it.
  11. Nov 3, 2013 at 1:23 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    If you have a manual trans. with a v6 TRD, then its a 6spd. I usually cruise around the 2000 rpm mark in mine when driving around town. No matter what speed limit is, i choose the best gear to keep close to that rpm. Not sure if its the most best option (im sure others have opinions) but its what I use and feel comfortable with.
  12. Nov 3, 2013 at 1:28 PM
    BradyT88
    BradyT88 Well-Known Member
    Just like this guy said, the V6 only comes with the 6 spd manual or the 5spd auto. The 4cyl comes with the 5 spd manual or the 4 spd auto.
    So either you have a 6 spd, or you have a 4 cyl motor. Or the previous owner of your Tacoma killed the 6 spd and dropped a 5 spd into it, in which case we have no idea what tranny you have and can't really help you...
    Use this link that Justus posted: http://www.grimmjeeper.com/gears.html
    Step 1: select the tranny:
    The 6 spd manual is the Toyota RA60F
    The 5spd manual is the Toyota R155F (which you will have to type in manually)
    R155F
    First Gear: 3.95:1
    Second Gear: 2.06:1
    Third Gear: 1.44:1
    Fourth Gear: 1.00:1
    Fifth Gear: 0.81:1
    Step 2: Select Tcase:
    Just put in 1 for the high range
    Skip Step 3
    Step 4: Axle Gear ratio
    If you have the V6 then it should 3.73
    If you have the 4cyl (6lug) it should be 4.10
    If you have the 4cyl (5lug) it shoudl be 3.31
    Step 5: Tire size
    Put in your tire size
    Then hit calculate, and towards the bottom you can choose different RPM to see how fast each gear goes, or what RPM different gears are at at a specifc speed.
