Where the hell does this wire go?
Discussion in 'Lighting' started by cmbtjnky, Dec 14, 2011.
  1. Dec 14, 2011 at 4:12 PM
    cmbtjnky
    cmbtjnky [OP] Active Member
    New hampshire
    05 DCLB, TRD Package
    5100's @ .85, 885 Coils, Light Racing UCA's, AAL's w/billy's, Nitto TG's 285/75/17, 17" Motto Metal boots, Painted valance, Painted rear bumper, Custom Grille, Hella Black magics in Grille, 1975 Toyo Landcruiser Front emblem.
    Hey guys, Im a newbie here with a newbie question. I have my hella black magic lights installed behind my grill. Everything is set up where it should be. My question is I want to run it with my high beams so that I can turn it on or off when I want. I just need to know how to do this in the simplest explanation possible. I just don't have a clue where this wire from the toggleswitch should go. Do I splice it in the high beam wire or place it somewhere in the fuse box. Sorry about this, I suck with electroics.
  2. Dec 14, 2011 at 4:29 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I see no reason taping into your high beam lead would not work. I've got basically the same set up, with Hella FF converted to HID behind the grill. Switch in one position, no Hellas with high beams, position two, Hellas on with high beams. Although I used the unused headlight socket as a power source, (left empty from a HID/projector upgrade).
  3. Dec 14, 2011 at 4:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You need a relay to make this work. That way the 'trigger' wire would get tapped into the high beam circuit and the power would go from fused power from the battery, to the switch, then to the relay, then out to the lights. With this configuration the lights will only come on when the high beams are on AND the switch is on.
  4. Dec 14, 2011 at 4:53 PM
    t4daddy
    North Alabama
    I didn't use any relay, and have the same set-up.
  5. Dec 14, 2011 at 4:54 PM
    cmbtjnky
    New hampshire
    Ok sounds good. I know I have the relay already for that wire. Everything is good to go in and in the right place. I am just having trouble understanding what to do with that one wire and where to put it.
  6. Dec 14, 2011 at 4:56 PM
    Pugga
    Massachusetts
    You should have a relay... Your aux. lighting shouldn't be taking power from the headlights.
  7. Dec 14, 2011 at 4:57 PM
    Pugga
    Massachusetts
    A test light would make it easier to find which wire going to the headlights is the 'hot' high beam wire. That's the wire you'd need to tap into.
  8. Dec 14, 2011 at 5:09 PM
    t4daddy
    North Alabama
    I know it's confusing, but the harness for my ballast (to my projectors) only uses one socket (this "used" to plug on the halogen bulb directly). The other one, (that "would have" gone to the passenger side light) is not used, and was just there, zip-tied out of the way. I used my multi-tester and found the high beam out put, connected it with a simple blade connector, grounded the second harness (for the Hellas) and everything as been fine for a little over a year.
  9. Dec 14, 2011 at 5:11 PM
    Pugga
    Massachusetts
    Oooh, I see what you're saying now. Your high beam wire isn't power anything except your off road lights because of your HID set up. In the OP's case though, he shouldn't pull power off the high beam wire because it will overload the circuit.
  10. Dec 14, 2011 at 5:17 PM
    t4daddy
    North Alabama
    Zackly!!!
  11. Dec 14, 2011 at 9:27 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    get a volt meter set it to 12 volts if there is a dial. unplug your head light plug turn your low beams then your high beams and see which one trips the volt meter when the high beam is on. once you found it simply peel back some of the protective loom and use a scotch lock to make the connection between the 2 and viola!
    hope this helped.
  12. Dec 14, 2011 at 10:31 PM
    t4daddy
    North Alabama
    Why not start with the high beams, if that's what he wants to tap?
