Where the hell is the towing converter relay 2006 Taco?
Discussion in 'Towing' started by 06Tacoman, Jun 28, 2010.
  1. Jun 28, 2010 at 8:01 AM
    06Tacoman
    06Tacoman [OP] Member
    Brian
    South Jersey
    06 SR5 Double Cab Short Bed
    Under the dash?
  2. Jun 28, 2010 at 8:46 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    what is a towing converter relay?
  3. Jul 10, 2010 at 12:01 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    On the parts shelf at the dealer, unless you have to tow package. In which case it is in the under hood fuse box. The towing converter is in the drivers side kick panel, again, if equipped. Both come as part of the Toyota towing wiring kit.
  4. Dec 7, 2010 at 5:25 AM
    06Tacoman
    Brian
    South Jersey
    My ground on the trailer was not attached securely, problem solved!
  5. Dec 27, 2010 at 12:52 PM
    jrider636
    jrider636 Well-Known Member
    justin
    tally,fl
    08 tacoma prerunner
    my running lights dont work on my boat but all others do. so i was thinking relay but how do u test to see if its bad?
