Where to buy a hitch receiver?
Discussion in 'Towing' started by smbundy13, Aug 3, 2010.
  1. Aug 3, 2010 at 2:04 PM
    smbundy13
    smbundy13 [OP] Well-Known Member
    Scott
    Birmingham
    as the title says, I am looking for a hitch receiver for my truck. I have read that there isnt a toyota hitch so I will have to get one elsewhere.
    where should I go? I have had experience with Draw Tite, but know about hidden hitch and U-Haul.
    where did yall go? where would yall go?
    Not sure how difficult it would be to put on myself.
    any info on this would be helpful
  2. Aug 3, 2010 at 2:21 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    I got mine for $90 at Advance auto parts, was very easy to put on. I have also seen them at wal-mart...
  3. Aug 3, 2010 at 2:53 PM
    JKD
    JKD Well-Known Member
    If you go to U-haul and have them put it on, it carries an installation warranty.
    From what I hear, U-haul uses the Valley hitch. I bought a Valley hitch from Amazon, and it also shows up E-trailer. It lists as a "Class III", but is marked as Class IV. Ridiculously simple to install, just make sure you have a good torque wrench that goes past 100 lb-ft.
  4. Aug 3, 2010 at 3:11 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    I had U-Haul install a hitch here in my home town. I was a couple states away on a trip and needed a little adjustment. I went to a U-Haul and there and they saw that it was one of their hitch/ball mount systems and fixed it for free.
  5. Aug 3, 2010 at 3:16 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    U-haul uses Valley for the round tube hitches and Curt Mfg hitches for the square tube hitches.
    I got the square tube Uhaul/Curt Mfg hitch from http://www.discounthitchcentral.com. There are several other places that sell them online, so you might find a better deal than at your local Uhaul or parts store.
    From Amazon I got the wiring harness that's listed in the Towing Bible thread.
    Installed both myself, but could have used another set of hands for installing the receiver.
  6. Aug 3, 2010 at 3:20 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
  7. Aug 3, 2010 at 3:21 PM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    I bought one off eBay for $120... it blows balls. Rusting like crazy, but it does work. Just appears the paint they used was useless.
  8. Aug 4, 2010 at 7:25 AM
    smbundy13
    Scott
    Birmingham
    thanks everyone for the good advice. I will probably go to a u-haul place since it is 5 minutes from my house. I could install it myself but dont have time right now.
  9. Aug 4, 2010 at 10:36 AM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    Less than 30 minutes...
    Worth the money saved.
  10. Aug 4, 2010 at 12:22 PM
    JKD
    http://www.uhaul.com/hitches/warranty.aspx
    If the hitch is ever damaged, if someone rear-ends you, etc., U-haul will repair or replace it.
  11. Sep 6, 2010 at 10:32 PM
    COEngineer
    COEngineer New Member
    Colorado Springs, CO
    Limited Ed
    Someone else posted about JC Whitney: http://www.jcwhitney.com/
    I found a class III Curt hitch for my 2003 Taco and after I applied the discount code I found on-line, I got the hitch and a 2" receiver for $132 including shipping. That's quite a bit cheaper than the $179+tax quote I got from Uhaul.
  12. Sep 7, 2010 at 6:13 AM
    Barnone
    Barnone Guest
    One last piece of advice, when you go to U-Haul ask for a receiver hitch and not a hitch receiver.
  13. Sep 7, 2010 at 6:19 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    My walmart has them. wierd, huh?
  14. Sep 7, 2010 at 6:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    When I lived in VA I was amazed at some of the crap I found in Walmart! Compared to the ones up here, they seem to carry everything you could ever possibly want/need.
  15. Sep 7, 2010 at 6:24 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have a Valley Hitch on mine, Its rated as a class IV. Super easy to install. 4 bolts (2 per side) onto the frame, then 2 bolts into the bumper. It uses all the factory holes. I recommed going for a 7pin plug instead of 4 because its easier to convert a 7pin to a 4 than to convert a 4pin to a 7.
  16. Oct 13, 2010 at 4:35 PM
    smbundy13
    Scott
    Birmingham
    well i got lucky and found a curt hitch on craigslist for $75. now i just gotta put it on this weekend.
    another question, is it a pain to hook the trailer lights harness? i wont be hauling a trailer big enough to use trailer brakes just lights..
    thanks for your help.
  17. Oct 13, 2010 at 5:18 PM
    Pugga
    Massachusetts
    You can get a plug and play harness that T's into your tail light plugs. All you have to do is take the tail lights off, plug in the harness and you're done. That will give you a 4-pin connection so you won't be able to tow a trailer with brakes unless it has surge brakes like a uhaul.
  18. Dec 11, 2010 at 6:20 AM
    South of Boston
    South of Boston Member
    Bob
    Rockland, Ma.
    2010 Tacoma 4x4
    First time post Any video's on DIY hitch Curt wiring harness installation?
  19. Dec 11, 2010 at 7:12 AM
    Pugga
    Massachusetts
    Should be plug and play, the harness T's into your tail light wiring and then you just run the 4-pin to the back of the truck and zip tie it to the draw bar. Shouldn't take more than an hour to install and you'll only need a screwdriver to remove the tail lights.
  20. Dec 11, 2010 at 12:09 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
