Where to buy color-matched handles.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imaking, Oct 15, 2010.
  1. Oct 15, 2010 at 10:18 AM
    Imaking
    Imaking [OP] Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    OME 885x coils, 5100's set at 0. Deaver 2" AAL and 5100s out back. AFE Pro Dry S drop-in, BHLM, '10 sport grille.
    I remember at one point stumbling across somebody who had ordered an entire color-matched set of handles for a double cab for like ~$90 shipped.
    Does that ring a bell for anyone? It looks like the price for the whole set has gone up on trdparts4u.com (I thought it was $140)
    Anywho, <$100 sounds better to me.
    Any help is appreciated :)
  2. Oct 15, 2010 at 10:31 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    its actually cheaper if you remove the door handles yourself and just paint them with color match spray can or get them professionally painted...its not hard and I painted my door handles along with my side mirrors...:D
    click for link -> Color Match Door Handles
    hope that helps you out...
  3. Oct 15, 2010 at 10:39 AM
    Imaking
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    I had a local guy quote me like $200 to paint them. He's nuckin futs.
    How is the paint holding up on your handles? ....neighbor :D
  4. Oct 15, 2010 at 10:43 AM
    T0LLPHR33
    BSP TRD Off-Road
    its holding really well...:thumbsup: I painted them over 3 years ago (handles/side mirrors) and they haven't chipped or faded yet...
    I'm not a fan of rattle can paint because not all the cans are pressurized the same and on a few cases in the past I got brand new rattle cans that were clogged in the nozzle and even after thoroughly cleaning the nozzle sprayer along with the tips it would still come out gummy...
    so I just bought the 2 stage BSP paint and clear coat from a friends shop here in LV and used his paint booth 1 weekend to do the job...:D
  5. Oct 15, 2010 at 11:21 AM
    Imaking
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    OIC. Well I can't paint too terribly well... nor do I have access to a paint boof :(
  6. Oct 15, 2010 at 11:34 AM
    T0LLPHR33
    BSP TRD Off-Road
    if you got a garage you can make yourself your own paint booth with some clear plastic...tape off where you want to merge the plastic together and run a fan blowing out of the plastic paint booth/garage that way you can keep the air cleaner...get yourself a dual filter face mask to keep paint particles out of your lungs...
    the main thing you gotta do right is prep work for the painting...if your prep work (sanding) isn't done well you will have low/high spots after applying the primer/paint and you will also see blemishes in the paint or dirt particles in the finish...
  7. Oct 18, 2010 at 9:18 AM
    Imaking
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    So in lieu of painting myself - anybody else have info on where to buy handles?
  8. Oct 18, 2010 at 10:05 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  9. Oct 18, 2010 at 11:25 AM
    Imaking
    Isaac
    Pahrump, NV
    08 TRD Off-Road
  10. Oct 18, 2010 at 12:26 PM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Just pull the trigger ... you'ld have them by now ...... ;).
  11. Oct 18, 2010 at 12:32 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Actually just tried trdparts4u and it wouldn't let me. Said the part is invalid or no longer available... couldn't even get to the point where you choose a color.
  12. Oct 18, 2010 at 12:51 PM
    jpmorrisvb
    Jimmy
    Virginia Beach
    I just went back in. Did you adjust the "year" .... it would let me buy them for my 2010 ..... but I did that in July.
  13. Oct 18, 2010 at 1:10 PM
    Pugga
    Massachusetts
    Didn't ask for a year, I clicked on the set for the 2005-09 models. There's a separate one for 2010 models for some reason. I thought they were the same but I guess not... I did clear the form, go into trdparts4u in a separate window and got the same message. OP, looks like you're stuck with Plan B.
  14. Oct 18, 2010 at 1:26 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Any of the on-line Toyota parts places should have them listed. If not, give them a call. When I ordered the Barcellona Red handles for my 09 last year, the place didn't list 09s or 3R3 color codes. Called them up and ordered that way. If I recall correctly it was about $150 then, might have gone up by now, but can also recoup some cost by selling your black handles. Sold mine for $60, so ended up costing about $100. Thought about painting 'em myself, but I've never had good luck with painted plastic and longevity. Was worth the 100 to me.
  15. Oct 18, 2010 at 1:34 PM
    T0LLPHR33
    BSP TRD Off-Road
    if both of you guys looked in my post #2 I attached a link to Toyotapartscheap.com where you can buy them...
  16. Oct 18, 2011 at 5:11 PM
    JJ5685
    JJ5685 Well-Known Member
    NC
    08 TRD Off Road v6 sr5 4X4
    pioneer stereo, 10" rockford fosgate punchgate sub, custom box, bull bar, custom trd decals
    That just says red, is it Barcelona or radiant. And are they clear coated
  17. Oct 18, 2011 at 5:15 PM
    Pugga
    Massachusetts
    Well... that link is a year old :rolleyes:
    And it worked for me, it showed me a bunch of colors.
  18. Oct 18, 2011 at 6:04 PM
    jpmorrisvb
    Jimmy
    Virginia Beach
    I bought mine from Toyota of Dallas .... 2010 Barcelona Red ... Access Cab .... 69211-AE020-D4 (2 of these handles) .... 69217-AE020-D4 (1 of these covers) .... 69217-0E010-D1 (1 of these covers)
    One cover has a key hole ... driver's side .... one cover does not have a key hole .. passenger's side .... botton line ... shipped .... $94.41 ... I hope that this helped.
