Where to buy hard to find fasteners for Toyotas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NM Lance, Aug 15, 2017.
  1. Aug 15, 2017 at 7:14 PM
    NM Lance
    NM Lance [OP] Well-Known Member
    Where is everyone finding some of the more obscure body fasteners for our trucks? I am searching for grille clips, door panel fasteners and a few electrical fasteners that I just can't locate.
    I am specifically after the grille fasteners at the moment. The local auto part stores typically can't get these and they usually recommend going to the dealership... but that is a looong drive for me just for a handful of small parts that they will more than likely have to order.
    To make things worse, websites usually just have a tiny, low resolution images of the fastener you want to buy so you really don't know what you are going to get until it shows up on your doorstep. I HATE buying auto parts online, but I will chance it if someone has a solid recommendation.
    Any ideas?
  2. Aug 15, 2017 at 7:17 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    I ended up grabbing some of those at the dealer but they are about $2 each. Call the dealer and order them online with the part #.
    NM Lance[OP] likes this.
  3. Aug 15, 2017 at 7:25 PM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    I've always had surprisingly good luck finding stuff at ace hardware; or at least suitable alternatives. But best bet would still be dealership or online.
  4. Aug 15, 2017 at 7:35 PM
    Glamisman
    Glamisman Well-Known Member
    when you say grill clips do you mean the black plastic "wedges" that you have to depress the center tab to get the grill off?
  5. Aug 15, 2017 at 8:19 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    the ebay ones from china can do, but some are thinner while some are thicker than OEM clips. And sometimes in the bunch you get, all of them are of different thickness, none is identical to each other
  6. Aug 15, 2017 at 10:12 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    GPsevinSixx and NM Lance[OP] like this.
  7. Aug 16, 2017 at 3:44 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    if you were close I would get you some, I have a friend who works in the service department at a Toyota dealership and always gets me various clips and fasteners when I am in need. Ebay does seem to be a good source when shopping from home though.
  8. Aug 16, 2017 at 4:05 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    The first time I did a grille (replacing the stupid burned bulb in OEM sealed headlight) I broke some, so I went to dealer and got the whole stock of 5 (all they had) 90467-12040 for about 2 bucks each. Later I found on ebay and other on-line places for half of that price. Got a bag of 10.
    China fasteners are not as good for the the reasons stated above and also for the plastic often not as durable as OEM ones. After I replaced these stupid sealed headlights with E-coded H4 reflectors I don't need to take out grille so often, so my OEM bag of these clips is still half full (or half empty for pessimists).
  9. Aug 16, 2017 at 4:26 AM
    NM Lance
    Yes, these things. I finally figured out the "trick" to them after I had broken half of them already, then they eventually just began breaking because they were so dried out.
  10. Aug 16, 2017 at 4:28 AM
    NM Lance
    I have had some luck at hardware stores. Mainly with trim fasteners. It's the more unique fasteners that I can't seem to find.
  11. Aug 16, 2017 at 4:32 AM
    NM Lance
    Thanks! I may have to set up an account on EBay or Amazon. I really do hate buying stuff online, but that is probably the best bet for this sort of thing. As others have mentioned Chinese replacements... I am okay with these as long as they hold tightly. I can't stand the rattles and squeaks that result from loose or old fasteners, that is mainly what I am trying to avoid.
  12. Aug 16, 2017 at 4:40 AM
    NM Lance
    Before anyone else destroys all their grille fasteners...
    The trick to removing them is to take a long, skinny flat screwdriver and press the tab down towards the hole in the grille attachment points while applying light pressure away from the front end of the truck.
    The trick to reattaching them is to fasten them to the grille FIRST, then carefully align them and snap the grille back into position.
    I wish I had known this when I removed them for the first time :frusty:
    As far as the door panel clips... You might as well just buy new ones and have them on hand before you remove the panel because they are going to break and distort regardless of how careful you are with them or which special tool you use to remove them.
    Plastic fasteners are the worst.
    jackn7 and Ihatetacomas like this.
  13. Aug 16, 2017 at 5:36 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
  14. Aug 16, 2017 at 6:14 AM
    NM Lance
    I have looked here and this is an excellent site. I struggle to navigate it though, unless I have a specific part number which leads me to ask...
    Where do you guys find part numbers for everything? Is there a website with the parts break-downs that would help with this? My Chilton and Haynes manuals obviously do not include these numbers since they are not affiliated with Toyota.
  15. Aug 16, 2017 at 8:08 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Ace, Amazon, or zip ties.
    Who am I fooling it's zip ties or leave the part off :D
    ToxicTwin and NM Lance[OP] like this.
  16. Aug 16, 2017 at 8:11 AM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
  17. Aug 16, 2017 at 9:25 AM
    RysiuM
    Rysiu
    There are two things that make me pissed about car mod/repair: zip ties on anything but cables and wire splice connectors in anywhere but trash can.
    skeezix and NM Lance[OP] like this.
  18. Aug 16, 2017 at 9:49 AM
    NM Lance
    Zip strips hold my world together sometimes.
  19. Aug 16, 2017 at 9:56 AM
    slander
    Hickory, NC
    Mine are stupid plastic clips the OEM uses that break the second you touch them, and torx fasteners. Lucky I have only found 3 of the later on my truck, owning a Jeep in the past has made me hate those fasteners!
  20. Aug 16, 2017 at 10:51 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
