Where to buy LED Reverse Fog Lights for the Rear?
Discussion in 'Lighting' started by RAD, Apr 20, 2010.
  1. Apr 20, 2010 at 12:59 PM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    I want something brighter than the cheap Harbor Freight Fog Lights I have in the rear of my Truck. I've seen plenty of guys rocking nice Orange or Clear LED Reverse Fog Lights.
    I'm looking for some ideas and places to buy it from. I'd like to get Clear ones and paint it Yellow or even just the Orange would be fine.
    I know some of you Off-Road guys have them, just don't know where to get it from.
    Thanks in Advance:mad:
  2. Apr 20, 2010 at 6:26 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
  3. Apr 20, 2010 at 6:36 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    You could add a switch for the rear turn signals and use a diode. So that they are on when you wish and still work as turn signals.
  4. Apr 21, 2010 at 7:53 AM
    joshua32
    joshua32 Well-Known Member
    Joshua
    Tyler, TX
    06 Prerunner SR5
    I'm not an electrical engineer, but wouldn't he need a diode in order to keep the flow of electricity one way?
  5. Apr 21, 2010 at 8:09 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I had lights mounted back there but hated it. Once the semester is over and I have time I am going to replace the reverse lights with bright white hi/los and wire them so that the standard reverse is lo, and then run an auxiliary switch that trips a 2x pull 2x throw relay that cuts the power to the low terminal and gives power to the high when on. I decided on a On-Off-On switch that will allow me to wire it so that the highs will only come on when I put it in reverse, and if I put it in the other on they will go on anytime. (Sucks for you if you tailgate me) Only thing I haven't nailed down is the bulb size I need to fit into the stock slot.
    Clean, cheap, and unique.
  6. Apr 27, 2010 at 10:58 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Tried the 886 fog bulb mod for the backup lights yet? Worked good for me and helped alot
  7. May 4, 2010 at 6:53 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i got a light at advanced auto that plugs into the 7-pin trailer hitch that has LED bulbs, it goes on when i go into reverse or you can just turn it on if you want
  8. May 4, 2010 at 6:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    whats wrong with the cheap harbor freight lights :D
