Where to buy new engine? 2.7
Discussion in '1st Gen. Tacomas (1995-2004)' started by gravgrip, Aug 21, 2021.
  1. Aug 21, 2021 at 11:01 AM
    gravgrip
    gravgrip [OP] Well-Known Member
    Kevin
    1998 Tacoma TRD 5-Speed
    Stock For Now
    Hello everyone. My engine needs to be replaced, unfortunately. My Gen 1 is in amazing condition so I will be doing the work to get her running right again. What's the best source place to buy a new engine? Any links would be very much appreciated.
    I was quoted $1800 for the install. Anything else I should replace when this is completed? I will replace the clutch while I'm at it
  2. Aug 21, 2021 at 12:13 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    I would look into getting a used good condition JDM engine.
  3. Aug 21, 2021 at 12:16 PM
    JudoJohn
    St. Louis
    I'm not sure they make new 2.7 engines anymore. The best you may be able to do is a remanufactured or rebuilt from a reputable company. Or, rebuild it yourself with new bearings, rings, etc.
  4. Aug 21, 2021 at 12:33 PM
    gravgrip
    Kevin
    Stock For Now
    Thank you, this is what I'm thinking. Any recommendations of reputable companies to purchase from?
  5. Aug 21, 2021 at 12:39 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I'd rather get a low mileage replacement than a rebuild. No one makes them better than Toyota after all. JDM sells used engines from Japan, usually with pretty low mileage. Due to emissions regulations in Japan, people get rid of their cars when the mileage is still pretty low. JDM then sells the engines over here.
    Superdave1.0 and JudoJohn like this.
  6. Aug 21, 2021 at 12:51 PM
    gravgrip
    Kevin
    Stock For Now
    Great to know, I've been looking for JDM. Is $2-3k to be expected? Here is one option I found https://jdmofsandiego.com/product/1...r-2-7l-engine-jdm-3rz-moto-3rzfe-distributor/
  7. Aug 21, 2021 at 12:56 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Is the bottom end bad? Maybe Toyota sells the shortblock still and just use your current cyl head. Dunno what your budget is.
  8. Aug 21, 2021 at 12:59 PM
    gravgrip
    Kevin
    Stock For Now
    Yea, the bottom end is bad. I'll look into this option, thank you. I just really don't have much knowledge when it comes to the engine
  9. Aug 21, 2021 at 1:13 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I would have your engine rebuilt by a reputable machine shop . This way you have a new engine with 0 miles on it . I wouldn't trust a used engine as there is just way to many unseen variables . I just don't understand why so many people here like used engines and the risk involved with them
    Places like this build performance crate motors
    https://www.yotashop.com/3rz-40/
    JGO, Abeyancer and stevesnj like this.
  10. Aug 21, 2021 at 1:18 PM
    gravgrip
    Kevin
    Stock For Now
    Thanks for the info. Maybe a stupid question, but if I purchased this: https://www.yotashop.com/toyota-4runner-tacoma-2-7l-3rz-engine-short-block-3rz-sb-9504/ would my mechanic install the block using existing components from my current engine?
    Thanks
    US Marine[QUOTED] likes this.
  11. Aug 21, 2021 at 1:18 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    They even make stroker kits and H beam rods for 3RZ motors
    Abeyancer likes this.
  12. Aug 21, 2021 at 1:24 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
  13. Aug 21, 2021 at 1:26 PM
    gravgrip
    Kevin
    Stock For Now
    Good to know, thanks. Will plug my vin in later on!
  14. Aug 21, 2021 at 1:35 PM
    Dirty Dude
    Dirty Dude Well-Known Member
    2004 Tacoma SR5 Xtra cab 5-lug
    Dirt, miles, and wear.
    A stock-spec rebuilt naked shortblock for $3300? Have 3RZs become that expensive? :eek:
    What is actually wrong with the bottom end? I find it hard to believe the block and crank are trash unless something very serious happened. It will likely be less expensive to get a rebuild if that's possible.
    Also not unheard of for those engines to be very poorly maintained partly for that reason. I'd still rather take my chances with one though. You just have to go into it knowing the engine could be full of sludge and abnormal wear for the mileage.
    Toyko Joe likes this.
  15. Aug 21, 2021 at 2:32 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Whats wrong with a junk yard motor...They all last forever.
  16. Aug 22, 2021 at 9:46 AM
    JudoJohn
    St. Louis
    Yes, I agree, that's a lot for a short block! I think it was 4800 for a long block form them, too.
    I think either a used engine or rebuild it yourself or have your mech do it.
  17. Aug 22, 2021 at 10:00 AM
    JudoJohn
    St. Louis
    If you do it yourself, parts would cost about $302 from Rock Auto
    rod bearings- 30
    main bearings 45
    head bolts- 30
    gasket set -72
    rings-50
    chain set -75
    Then you have the machine shop charges- valve job- 300-500
    clean block
    hone cylinders
    polish or grind crank
    not sure of cost- est $400 + -
    Rock auto also has a long block for $2489.
    Toyko Joe and US Marine like this.
  18. Aug 22, 2021 at 10:25 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Most auto part stores and other mfgs that sell very cheaply priced long blocks and short blocks will have cheap quality parts installed . Yes the price is very cheap and easy on your wallet but I've seen many of the cheap remanned engines with catastrophic failures
    Most of these engines use hypereutectic pistons which are made from a silicone alloy and are very fragile . They don't work well with boosted applications and also can be damaged from excessive spark knock . They literally shatter like glass
    This is why I like using Forged pistons from well known mfg's
    Ritchie and Abeyancer like this.
  19. Aug 22, 2021 at 11:29 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you get a rebuild from YotaShop or Yota1 at least you know you're getting quality parts from a quality Toyota builder. Toyota engines don't like cheap exterior engine parts so I imagine cheap internals can be just as bad. Even JDM motors should be opened up to see what condition everything is in and if it needs a quick rebuild or not. Could end up in the same boat as before if you're not cautious.
    Tour991 likes this.
  20. Aug 22, 2021 at 11:44 AM
    gravgrip
    Kevin
    Stock For Now
    I need to find out exactly what is wrong with the bottom end. My knowledge of engine terminology is pretty poor, but my mechanic said the problem was coming not from the head or valves, but deeper within the engine. He said my best option would be a replacement engine.
    I'm going to call a bunch of local junkyards tomorrow and hope I can find something. I found some JDM engines for a little less than $2k. I was told around $1800 for install, will change the clutch while I'm at it.
