where to buy spindles from? and my set up!
Discussion in 'Suspension' started by SoCalBlack08, May 9, 2010.
  1. May 9, 2010 at 6:24 PM
    SoCalBlack08
    SoCalBlack08 [OP] Well-Known Member
    CA
    08 PreRunner DC
    where the heck can i buy the camburg spindle from? im trying to order but im having no luck plus i heard a site gives us a discount on them :D
    and this is what im going to have done once the parts get here....
    -Spindles and a 1 inch spacer from a 4 runner(i think they fit) and extended brake lines =5" front
    -2" AAL and 2" block in back to level it out and extended brake lines( i think i need them) and the 5150 shocks= 4" rear
    -33" tires and 17" wheel that i havent decided exactly what i want yet
    what do u guys think?
  2. May 9, 2010 at 6:36 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    U can buy the spindles right from Camburg.
  3. May 9, 2010 at 6:38 PM
    only_K
    only_K 1st Gen. Pride
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    K&N drop in filter, Magnaflow Exhaust, Billet grille. All 4 Bilstien 5100s. Fronts set at 2.5". Rear 2" AAL.
    I dont know too much about lifts, but i heard its not a good idea to stack lifts. Again, not to familiar.
  4. May 9, 2010 at 6:38 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Get rid of the 1" spacer and the 2" block + AAL. Get a rear leaf pack.
  5. May 9, 2010 at 6:39 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Yea i would skip the spacer and blocks and sit a little nose high
  6. May 9, 2010 at 6:52 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    but i think a 1" spacer isnt that bad...and the rear is all i can afford after the spindles/tires/wheels haha
  7. May 9, 2010 at 6:53 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    i dont see it on their site?
  8. May 9, 2010 at 6:56 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    get the 5100's for the front and set them at .75" if you want the extra inch. much rather run those (which i do) over a spacer lift
    edit: better idea since your dropping the coin anyway do it right the first time. get yourself the spindles, a nice coilover, 5150's for the rear and a deaver or alcan leaf pack. :thumbsup: sittin pretty you will be
  9. May 9, 2010 at 8:22 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    that route is VERY expensive haha
    i kinda just wanna know if everything seems right
  10. May 9, 2010 at 10:03 PM
    SoCalBlack08
    CA
    08 PreRunner DC
  11. May 9, 2010 at 10:08 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Go with the 5100's up front and set them at first setting as stated above. Just look for a nice used pair.
    For the rear avoid a block. You can get a used 3" all pro leaf pack for like 300 or 350 on here sometimes.
  12. May 9, 2010 at 10:10 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    how bad is the block and AAL combined?
  13. May 9, 2010 at 10:17 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Well people tht run blocks and later ditch them realized they should have never bought them. Take Amir(sandman) for instance. He has the camburg spindles and was running blocks. He ditched them finally and got the 3" leaf pack. He loves it.
    I am planning on buying the spindles as well. In my opinion you should just put the spindles up front for now and later on down the line buy some coilovers if you want more lift. For the rear I already have the 3" leafs and I'm planning on setting my coilovers to 1" and then getting a custom rear shackle mount made that gives another inch of lift.
  14. May 9, 2010 at 10:29 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Not that bad, just not that great either. A block promotes axle wrap (wheel hop on hard acceleration) so most steer from them.
    Toyota offers a technical service bulletin that will allow you to get a FREE ad a leaf. Lifts the rear of the truck about 1" and increases load capacity and prevents the rear from bottoming out and slamming bump stops. However the truck will ride like a rock and will not flex as easily. You gotta research this A LOT.
    Spindles are a great way to lift a truck, takes the load off the balljoints, free's up any preload on a coilover, if there was any to begin with and widens the track approximately 1/2". Not to mention they're strong as heck... only problem is, do you wanna spend $900 for a set?
    Cheap and safe formula for lifting: Bilstein 5100-set at whatever height you desire. TSB add a leaf from toyota + 5125 shocks in rear. 285 tires- Looks awesome.
  15. May 9, 2010 at 10:34 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    ^^^^^^^^^^but i want about 5-6" of lift without paying the crazy procomp/fabtech prices.
    but thank for the info :)
  16. May 9, 2010 at 10:37 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Hey socal do you offroad?
  17. May 10, 2010 at 10:37 AM
    SoCalBlack08
    CA
    08 PreRunner DC
    not much but i do still want it to be a little functional...not a complete mall crawler haha
  18. May 10, 2010 at 10:47 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Well then just get the setup you said. If you don't like it and you realize that just maybe we have some knowledge....you can always change it out.
  19. May 10, 2010 at 10:49 AM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    listen to JD he knows what he is talking about and the example of Amir was a good one I talked to Amir a few times now wishes he wouldve went straight to his leaf pack from the start.....blocks are no good man...
  20. May 10, 2010 at 10:54 AM
    SoCalBlack08
    CA
    08 PreRunner DC
    i trust u guys but i just cant afford the new leaf pack and i dont want to wait for someone to put one up for sale...so what exactly makes the rear a horrible ride? stiffness?
