Where to buy TRD fender-flare rubber trim?
Discussion in '1st Gen. Tacomas (1995-2004)' started by WeaponR, Mar 22, 2010.
  1. Mar 22, 2010 at 1:09 PM
    WeaponR
    WeaponR [OP] Member
    I have a 2001 Tacoma Prerunner TRD with the black fender flares. The rubber seal that goes between the body and fender flare has come off in some areas and I am trying to find a replacement. My trips to the local automotive stores have come up empty as no one has specifically what I need.
    Any ideas on where I can get this (either locally or online)?
  2. Mar 22, 2010 at 1:10 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    hit up a dealer
  3. Mar 22, 2010 at 4:32 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (234k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ AFE air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    X2 ^^
    Pretty much if it's an OEM part of the truck you can get it at the stealership.
  4. Jun 1, 2011 at 6:40 PM
    sewerdog
    sewerdog Member
    stevenson ranch ca
    01 prerunner
    it is only sold at toyota about $20.00 apiece
  5. Jun 2, 2011 at 1:18 PM
    Rozz
    Rozz Well-Known Member
    Sturgis, SD
    '15 TRD Sport
    Stuff
  6. Jun 4, 2011 at 1:49 PM
    darcfenix
    darcfenix Well-Known Member
    Jim
    Cincinnati, OH
    '14 Tacoma Double Cab 4x4 Automatic
    My truck was missing the driver's side rear gasket; went to the dealer, found out they called it the driver's side rear wheel opening pad and cost me $17.97 tax included.
    Williambailey0706 likes this.
  7. Jun 4, 2011 at 11:26 PM
    Big M
    Big M Well-Known Member
    Central Connecticut
    02 TRD xtra cab 3.4 5spd
    bilstein RCD 5100's all around, eibach coils, rear add a leaf, diff drop, cb drop, 33x12.5x15 tires, HID headlights, pioneer mp3 head unit, 12" sub with mono amp, grey wire mod, 2-low mod
    There was actually a service bulletin for this issue, found in my service history at Toyotaowners.com that my truck had them replaced before I bought it.
    62000 STRUCTURE:BODY Bulletin No: BO00902 Date of Bulletin: 09/26/2002 Summary Description:
    SOME PRERUNNERS AND 4X4S MAY EXPERIENCE A CONDITION WHERE THE RUBBER PAD BETWEEN THE FENDER FLARE AND THE BODY MAY APPEAR LOOSE. *TT​
  8. Aug 1, 2011 at 10:32 AM
    Rojo
    Rojo Active Member
    Texas
    12 TRD OffRoad 4x4 DCSB - Super White
    K&N, 2.5 lift/leveled, TRD FJ Wheels, 285/75R16
