Where to drive 10 miles 4x4 per month if not off road??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tom_gunnison, Apr 2, 2020.
  1. Apr 2, 2020 at 6:24 AM
    tom_gunnison
    tom_gunnison [OP] Member
    2020 TRDOR
    In the manual it says you should drive 10 miles a month in 4x4 in order to properly lubricate the front drive components. I just encountered my first month where we never had enough snow fall to warrant engaging 4x4 while driving nor did i take the truck off-road. (new truck owner)
    There is a lot of discussion on the forum about the dangers of driving in 4x4 on dry pavement, especially when making turns (the manual also says to avoid this). Now I know I could likely find a fairly straight section of highway to get the 10 miles in, but my question is why is driving on dry pavement so bad? I know when making turns the inside wheels will want to turn at a different speed from the outside wheels, which, if the differentials were locked, would be problematic. But on these trucks aren't the differentials "free" and isn't that why locking differentials are a desirable feature on these trucks?
    Clearly somewhat new to this world so any explanation is much appreciated.
    dmurph1996 likes this.
  2. Apr 2, 2020 at 6:31 AM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    When making turns in 4wd, the rear axle follows a different ‘route’ than the front axle, which means the front and rear axles are technically at minutely different speeds when turning, which leads to binding in the transfer case. This is exaggerated with a locking differential.
    As far as where to get your 10 miles in, just find a straightish road and throw it in 4wd and just avoid and super sharp turns. It’ll wear out tires before it does any internal damage.
    JVL1985 likes this.
  3. Apr 2, 2020 at 6:31 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    It'll be easier if you Google and read why a part time 4WD (transfer case without a differential) can't be used on pavement.
    http://4x4abc.com/4WD101/def_turnpart.html
    Driving on pavement in a straight line isn't an immediate risk. The driveline can tolerate that in theory. In practice not all your tires are exactly the same diameter, sway, make minor corrections. So in 10 miles the 4x4 system could start to bind, but a short distance is OK.
    It's making turns that are the primary risk with a part time 4WD system. Our type of 4WD can't tolerate turning unless the surface has some ability for the tires to scrub, i.e. mud, snow, dirt, sand, etc.
    You need to get the lube circulating in the front end and t-case periodically. A dirt or gravel road is all you need for that.
    tonered likes this.
  4. Apr 2, 2020 at 6:33 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you think of your transfer case as a locked center differential it will make sense.
  5. Apr 2, 2020 at 6:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I wouldn't get hung up on the 10 miles per month thing. That's something Toyota puts in the manual to cover their ass. That way, someone who has never engaged 4wd doesn't try and raise a fuss when they do engage it after 10 years and something doesn't work. If you're regularly using it over the winter, then that's enough exercise for it.
  6. Apr 2, 2020 at 6:35 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    I do straight roads and light turns on rainy days.
    CrufflerJJ, SR-71A and Bannerman like this.
  7. Apr 2, 2020 at 6:40 AM
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
    I flick mine on sometimes on a straight section of road of maybe a mile or so at a time. Doesn't have to be 10 miles all at one time I don't think.
    Doubt if I actually get 10 miles a month doing this either but I try. I also turn it off before coming up to any turns or curves if on pavement.
    This is all anecdotal, of course.
  8. Apr 2, 2020 at 6:47 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
    that and also any offroading done in the summer.
    EatSleepTacos[QUOTED] likes this.
  9. Apr 2, 2020 at 6:50 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    In a heavy rain you should be fine in a relatively straight line. The water provides enough slippage to deal with the small amount of bind.\
    @EatSleepTacos is right though... if you get a few good uses out of it a year it will be fine. Just take a trip to a forest road every 2-3 months and give it a good run.
  10. Apr 2, 2020 at 6:53 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Straight roads, preferably on rainy days.
  11. Apr 2, 2020 at 7:04 AM
    Shellshock
    Iowa
    Straight road. Takes all of 10 minutes.
  12. Apr 2, 2020 at 7:06 AM
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    Same for rainy days. I try to engage 4x4, 4Lo, and diff lock once a month. This keeps actuators working. Forums for older Toyotas address this all the time. The 4Runner forum had a monthly reminder thread that popped up once a month to help everyone remember.
  13. Apr 2, 2020 at 7:11 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I'm not familiar with Toyotas TC but many have dual oil sumps, upper and lower, running it once a month would ensure their is oil in the upper sump.
    Just run it a bit on the road.
  14. Apr 2, 2020 at 10:33 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Industrial parks usually have large grass lots, state parks, gravel roads or lots. I wouldn't get too hung up on 10 miles, I'd just find a gravel lot or road, and just use 4wd for a few hundred feet every month or so.
  15. Apr 2, 2020 at 10:47 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    This is what I do. I'll be buzzing down the freeway and randomly think about my 4wd and switch it on for a straight stretch. Never 10 miles though. But a straight mile or two is usually easy to find. I know I've never done it monthly, but I try and remember!
    TacoManOne likes this.
  16. Apr 2, 2020 at 10:47 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Cause ThE iNtErNeT sAiD sO
    It's certainly good practice to avoid sharp turns on dry pavement in 4x4, but your truck will not explode..
    In my mind the biggest possible issue would be releasing any built up tension as you switch back to 2x4. Specifically the leading edge of the teeth on the ADD and t-case sleeves. But again its not the end of the world in my opinion
    AKGSD likes this.
  17. Apr 2, 2020 at 10:51 AM
    YF_Ryan
    Kent, WA
    I don't know what the weak link is in our trucks, but I've seen pics of transfer cases online that blew up from this. One specific story I recall, though I can't remember what type of truck it was, I think some Chevrolet. They forgot to take it out of 4wd and drove across Montana or something like that. Personally, I've forgotten to take out 4wd after coming off the sand at Moses Lake and made it all the way out to the freeway and a number of miles down it. Definitely clunked hard when it disengaged. Usually I'd notice it was engaged, but I was towing a trailer, so maybe concentrating on that made me not realize.
  18. Apr 2, 2020 at 10:55 AM
    SR-71A
    Zack
    Southern Maine
    Well its a Chevy, what else would you expect?? :D :boink:
    That clunk coming out of 4wd is what I was talking about
    YF_Ryan[QUOTED] likes this.
  19. Apr 2, 2020 at 11:01 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Dirt/gravel road every once in a while. Good to go. Don't over think it.
    Chew likes this.
  20. Apr 2, 2020 at 11:03 AM
    Black taco.
    Black taco. Well-Known Member
    4x4. MT.
    you should never engage 4x4 while “buzzing down the freeway.”
