where to find a dash light dimmer switch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RobbySkateboard, Jul 23, 2013.
  1. Jul 23, 2013 at 10:40 AM
    RobbySkateboard
    RobbySkateboard [OP] Well-Known Member
    Robby
    Thousand Oaks, Ca
    05 4x4 Tacoma TRD Sport DCSB
    installing a in dash navi/video system about a year ago I somehow shorted something out in my dimmer switch (Jerez was the one who figured that out for me) and I haven't gotten around to buying a new one yet because it's only a minor annoyance that I can't dim my dash panel, but I think because it's not plugged in other things aren't working either, such as the lights on the steering wheel controls, the light in the window switch, my AC unit lights, etc. Could anyone confirm that this would cause that problem (if it's not plugged in it wouldn't be creating a circuit right?) and also where I could get a new one from other than directly from my Toyota dealer who want like $140 for one?
    Thanks.
  2. Oct 18, 2013 at 9:50 PM
    DOUBLEJTACOMA
    DOUBLEJTACOMA Active Member
    Jeremy
    Jasper, Alberta
    Blacked out SR5
    -Black Halo Projector Headlights with HIDs -Black Billet Grille -Night Shaded Tail Lights -Exhaust (Magnaflow) -URD 2.7L Supercharger (soon, may need help)
    Bump. Having same problem
  3. Oct 18, 2013 at 9:55 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I had the same problem while messing with some wires and shorted it. dealer quoted same price. issue is the dimmer switch is only in our trucks and theres no after market out there. lucky they covered it under warranty
    if the switch is unplugged my shifter lights wouldn't work and the steering wheel lights if I remember correctly, mines 2013 Tacoma don't know if circuits are different or not
  4. Oct 19, 2013 at 8:38 AM
    RobbySkateboard
    Robby
    Thousand Oaks, Ca
    I still haven't fixed mine, I think I'm going to go to a pick apart place near me and see if I can't find one of those, a new shifter knob, a back left 4x4 mudflap, a roof rack, back window motor and a few other little things I have written down but can't remember
  5. Oct 19, 2013 at 9:48 AM
    DOUBLEJTACOMA
    Jeremy
    Jasper, Alberta
    Blacked out SR5
    Mine occurred when I put an add a fuse to provide power for 2 plx gauges. I think something got shorted. Now, the dimmer setting on the tacoma gauges seems stuck on a high setting, with the dimmer doing nothing. Also, the HVAC lights don't work at all. Kind of a nuisance when driving at night... Might it just be a blown fuse? Suggestions?
  6. Oct 19, 2013 at 9:51 AM
    tacodane
    Dane
    If your dimmer switch is not working it that could have shorted. the only thing else it could be would be something in the cluster but you said its on high so it cant be that. if you know someone else with a Tacoma you can attempt to use there working dimmer and see if yours is shorted. if that's the cause its a $140 part
  7. Oct 19, 2013 at 10:02 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  8. Oct 19, 2013 at 3:03 PM
    tacodane
    Dane
    Those all should work. Toyota only use that design/type of dimmer switch. go luck with the issues.
  9. Feb 8, 2015 at 10:47 AM
    tacodane
    Dane
    Did you ever order a switch? I need a new one since I shorted the switch out again
