Where to find a larger gas tank?
Discussion in 'Toyota Trucks & SUVs' started by cldowhan, Nov 23, 2010.
  1. Nov 23, 2010 at 12:23 PM
    cldowhan
    cldowhan [OP] New Member
    Alberta
    09 Tacoma dbl cab
    ARB Delux Bull Bar, Raider Cap.
    Hello everybody and thanks for your help. I have a 2009 Tacoma Dbl Cab 6 speed manual. I'm having a lot of trouble finding a larger gas tank to install. Basically what I'm looking for is what The Long Ranger has developed for the Toyota Hilux the TR63/TR63A, is there anybody in Canada or the USA can can make this or has something similar?
  2. Nov 23, 2010 at 5:44 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    There should be some place to make custom tanks... Otherwise, Jerry Cans? 300-400 mile range not enough? A second full tank adds a lot of weight and will hurt mileage. But, if there are no secure fuel sources, then that's the way to go!
  3. Nov 23, 2010 at 6:58 PM
    blackwidow2009
    blackwidow2009 Well-Known Member
    Brian
    Cleveland
    09 Access Cab 4X4 TRD w/ SR5
    2.5" front lift Daystar coilover spacer. 2.5" rear lift add-a-leaf N-Fab wheel to wheel nerf/step bar Polished Stainless Leer cap from my 2000 Tacoma --- It does fit; don't let them lie to you
    I would love to find an additional tank to add to the factory one. I have been looking for one that is mounted under the truck just like the factory, and it ties into the factory tank. I don't want a second fill spout nor do I want a second fuel pump. I know a tank can be made that just fills and empties in and out of the main/factory tank. Those silly transfer cases are a pain, especally with a cap on the truck, and it's a pain to then fill the factory tank.
    I deffinatly dont worry about the extra weight because is really is nothing. Figure a gallon of water weighs just under 8 lbs, and gas is less then water. A 50 gallon tank filled with gas will weigh less then 400 lbs...hell people put more weight then that on their trucks between armored front and rear bumpers, skid plats, sliders, caps, or truck boxes. And the loss in miles per gallon....hell, that's soo small, who cares. lol
    I just want it so I can go longer between fill ups and ride out the times the gas companies want to rape us with jacked up prices.
  4. Nov 23, 2010 at 7:01 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
  5. Mar 7, 2011 at 4:00 PM
    steve103
    steve103 Well-Known Member
    steve
    santa cruz ca
    07 taco
    arb bumper,bilstein shocks,886 ome springs,ar mojove rims,2optima batteries,custom electrial.on board air,cb,14gal frontrunner water tank,frontrunner roofrack
