Where to find reverse light wire on 2012?
Discussion in 'Lighting' started by claymore, Dec 22, 2012.
  1. Dec 22, 2012 at 3:39 PM
    claymore
    claymore [OP] Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    Can anyone help me find a reverse light wire under the dash of 2012 DCSB? I am wonder where to look. I dont want to pull my entire dash apart. I am adding some aux reverse lights and I am going to use a relay under the hood. I would like to keep from having to run a wire all the way from the back. I am a cheap bastard and copper is expensive!:eek:
  2. Dec 22, 2012 at 10:59 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Why don't you just tap into the tow plug wire? Unless you're adding a switch as well
  3. Dec 23, 2012 at 10:41 AM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
  4. Dec 23, 2012 at 11:02 AM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Ya after I started reading I figured you wanted a switch :p my bad
