Where to find spider gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco2sday, Dec 19, 2023.
  1. Dec 19, 2023 at 6:15 AM
    Taco2sday
    Taco2sday [OP] Well-Known Member
    Idaho
    98 5lug/98 sr5
    Pretty sure I shit out a spider gear. Truck pulls one way on the gas and then goes straight when I’m off the gas. Can’t figure out where to get new spider gears at. 98 tacoma 2wd 2.4
  2. Dec 19, 2023 at 6:28 AM
    1997tacomav6
    Denver
    Might be easier to just get a used 3rd member instead for a few hundred dollars or axle
    SR-71A and wilcam47 like this.
  3. Dec 19, 2023 at 6:38 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    What part of idaho and is this for your 5lug? I have two spare 4.10 ratio 8.4 rear diffs in my shop.
  4. Dec 19, 2023 at 6:44 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Could be an axle more likely than a spider gear but definitely easier to find a third member to drop in replacement. If it were a spider gear, the broken chucks would have likely destroyed the ring and pinion.
    Taco2sday[OP] and SR-71A like this.
  5. Dec 19, 2023 at 6:50 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Would the truck even move in that case? Open diff.. power going to the side without any load and all that..?
  6. Dec 19, 2023 at 6:56 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I'd look at a rusted and broken frame before I'd consider broken spider gears. If it shifts under acceleration, you would get the exact scenario you are describing. I'd also look for loose U bolts or broken leaf springs.
    RelentlessFab likes this.
  7. Dec 19, 2023 at 8:17 AM
    Taco2sday
    Idaho
    98 5lug/98 sr5
    Yes it’s for the 5 lug.
  8. Dec 19, 2023 at 8:18 AM
    Taco2sday
    Idaho
    98 5lug/98 sr5
    Definitely rust free CA truck and frames been coated. But definitely need to check u bolts
  9. Dec 19, 2023 at 8:19 AM
    Taco2sday
    Idaho
    98 5lug/98 sr5
    That’s exactly what I thought. I think skmething might be stuck in there making more power go to the right
  10. Dec 19, 2023 at 8:21 AM
    Taco2sday
    Idaho
    98 5lug/98 sr5
    Close to Boise area
  11. Dec 19, 2023 at 8:22 AM
    Speedytech7
    Ah bummer, don't have any of the 7.5 diffs laying around.
  12. Dec 19, 2023 at 8:42 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I have a guy with tons of 7.5 diffs laying around. Let me know the ratio. He will ship a third member in a 5 gallon bucket to you if it is the diff. Let me know if you want me to reach out but didn’t want you to turn on the parts cannon before diagnosing.
    Taco2sday[QUOTED][OP] likes this.
  13. Dec 19, 2023 at 8:48 AM
    Taco2sday
    Idaho
    98 5lug/98 sr5
    I’ll drain the fluid today and see if a bunch of pretty glitter comes out and then dig into it with a bore scope. Everything else looks good. No broken shocks, leafs or loose u bolts
