Where to get 5.29 gears for 2010 4x4
Discussion in 'Off-Roading & Trails' started by trailertrashman, Sep 7, 2011.
  1. Sep 7, 2011 at 11:02 AM
    trailertrashman
    trailertrashman [OP] Active Member
    10 Reg Cab 4x4
    Folks,
    have searched and found places that have 4.56 and 4.88, but am thinking of getting 5.29 gears for 2010 Reg cab 4x4 2.7 5 speed. I know it will hurt gas mileage but truck is used mainly for work commute in city and towing RV on freeway. Checked online at East Coast and Randys but front not listed, I can call but though might ask TW collective.
    TIA
    Bobby
  2. Sep 7, 2011 at 11:05 AM
    Manwithoutaplan
    ID
    Try east coast gear supply i believe they have them. In the 3rd member he has the 5.29 listed.
  3. Sep 7, 2011 at 11:05 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    what size tires will you be running? just curious..
  4. Sep 7, 2011 at 11:17 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Unless your running at least a 35" tire, that is too low of gears.
  5. Sep 7, 2011 at 11:18 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i didnt think anyone makes 5.29 for the front
  6. Sep 7, 2011 at 11:29 AM
    97yota4wd
    Eric
    Mesa, AZ
    yeah you need a 35 with those gears...
  7. Sep 7, 2011 at 11:38 AM
    trailertrashman
    10 Reg Cab 4x4
    Just running 265/75/16 Tires. Know this will be low gear, but for mostly city driving makes little difference, and would be nice to have the power to tow on freeway. Toyota engines are made for high rpm operation and since I only tow few times year should not cause problems, but then again I regard the truck as an expensive toy
    Bobby
  8. Sep 7, 2011 at 11:43 AM
    97yota4wd
    Eric
    Mesa, AZ
    dude those tires are 31.6 inches tall. do not go with 5.29s. DO NOT.
    not even 4.88s.
    4.56 is the biggest i would go with that. you will be red lining at 70mph with that gear ratio
  9. Sep 7, 2011 at 11:44 AM
    Yoytoda
    Roland
    completely stock
    think of it this way with 4.88 the gear ratio in 5th is the same as stock 4.1 in 4th
    so if you go to 4.88s itd be like your a gear lower
  10. Sep 7, 2011 at 11:44 AM
    97yota4wd
    Eric
    Mesa, AZ
    at 75 mph you will be at 4219rpms in 5th gear with a manual.
  11. Sep 7, 2011 at 11:47 AM
    Manwithoutaplan
    ID
    the motor would be screaming :$
  12. Sep 7, 2011 at 11:48 AM
    Yoytoda
    Roland
    completely stock
    where do you calculate that. i got about 3500
  13. Sep 7, 2011 at 11:48 AM
    Yoytoda
    Roland
    completely stock
    your a v6 too
  14. Sep 7, 2011 at 11:49 AM
    97yota4wd
    Eric
    Mesa, AZ
  15. Sep 7, 2011 at 11:52 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    DO IT!
  16. Sep 7, 2011 at 12:01 PM
    Yoytoda
    Roland
    completely stock
    265/75 16 has a 100in circumference. the is 63,360 inches in a mile. the tire would have to turn 634 times to travel 1 mile. with 5th gear is a .81:1 ratio with 5.29:1 rear ratio it would be 4.3:1 as a final ratio.
    634 times 4.3 = 2700
    it would take 2,700 revolutions of the engine to make one mile. so... 2700rpm=60milesper hour since 2700 revs per minute and if it takes 1 minute to go one mile you get 2700rpm=60mph
    60mph-75mph=20% change
    2700+20%= about 3250rpm at 75
  17. Sep 7, 2011 at 12:03 PM
    97yota4wd
    Eric
    Mesa, AZ
    3250 cant be right when im close to that with stock gears and 31s..
  18. Sep 7, 2011 at 12:05 PM
    Yoytoda
    Roland
    completely stock
    well first gens might have a different rear ratio and different 5th gear ratio...
    i used the info for the 2010 4cyl drivetrain
  19. Sep 7, 2011 at 12:06 PM
    97yota4wd
    Eric
    Mesa, AZ
    ^ oh okay you may be right then.
  20. Sep 7, 2011 at 12:10 PM
    Yoytoda
    Roland
    completely stock
    smaller tires give you higher revs and you may have 4.56 gears stock since that was an option on first gen 4 bangers.
