Where to get 6x9 speaker harness??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cverneau, May 10, 2011.
  1. May 10, 2011 at 5:16 AM
    cverneau
    cverneau [OP] Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    I'm replacing the front lower 6x9 speakers in my 2011 AC.
    I'm making my own adapters, so I'm not gointg through Mr. Marv or ********* for anything. I don't want to cut speaker wires. I just want to get the speaker adapters that will plug into the existing harness.
    ********* has them for $15.
    I also found these:
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-769
    Anyone know of anywhere else I could pick up a pair of harnesses for cheap??
  2. May 10, 2011 at 5:53 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    you can make a set with a couple quick clips and wire, they are very simple. Also your stock speakers are not 6x9, and if you making speaker adapter i would recommend you go with 6.5" instead. They are a much better speaker acoustically, and there is a lot more out there to choose from.
  3. May 10, 2011 at 5:59 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    IIWM I'd spend the $15 for a factory built harness. You are much less liklely to have any connection problems that way.
  4. May 10, 2011 at 6:05 AM
    cverneau
    Craig
    Cheshire, CT.
    Everything I've read on and checked says that my existing speakers are 6x9. I may make my own speaker adapters or I might try to remove the speaker from the existing adapter that it's attached to.
    As for the harness, I really don't want to make my own.
    I've currently found references for Scosche p/n SHTA02B and Metra p/n 72-8104 for the wiring harness. Will either of these work for the 2011?
    Anyone have any other p/n's that I should look for??
  5. May 10, 2011 at 11:54 AM
    cverneau
    Craig
    Cheshire, CT.
    Bump...
  6. May 10, 2011 at 5:18 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I got mine from Best Buy. Go right back to the install bay counter and they will sell them to you. I paid $12 for a set of 2.
  7. May 10, 2011 at 5:21 PM
    B R
    B R Active Member
    Los Angeles, CA
    '10 AC 4 Banger Auto
    I just cut apart my old speakers to act as both a mounting adapter & for the wiring too. I soldered the new speaker wires to the old terminals, so now it's almost like a factory setup, stock connector plugs into the same place as before, but with better sound :D.
