Where to get a Frame Swap in Denver, CO
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hrry4x4, Nov 6, 2024.
  1. Nov 6, 2024 at 8:12 AM
    Hrry4x4
    Hrry4x4 [OP] Member
    2004 Red Tacoma SR5 4x4
    Hi,
    I have a rusty 2004 Northeast Tacoma (2.7L 4x4 5dpd, extended cab) and I have been trying to find a solution/repair.
    I recently found a beautiful frame that matches my truck, but I am curious about what the swap would look like. I watched a video on Youtube (https://youtu.be/Urqq8FbVvb0?si=hFBj-ofQpWFqhxR9) where the frame of an old Tundra was swapped without ever dropping the motor or transmission, but it would certainly take me over two or three weeks to do all of the prep work and do the swap myself/with a buddy.
    What shops do you guys recommend in the Denver/Boulder/Front Range area to do that kind of work and what do you expect it would cost?
    TIA,
    Harry
    Black97v6MT likes this.
  2. Nov 6, 2024 at 8:35 AM
    PathFinder1776
    PathFinder1776 Well-Known Member
    Colorado Front Range
    2003 DCSB TRD OR 4WD
    TRD S/C & TRD Boost Gauge Snugtop Topper Chevy 63 Swap, Gen 1 Raptor Shocks Boxed rear frame Aluminum F/R bumpers, sliders AEM 340 Fuel Pump Odyssey 27F Battery Shifted LCAs UCAs Icon 2.5 Ext. Coilovers
    There are probably a few shops that could pull it off...they're not cheap. I got a quote once, and only once, for a gear swap with the 3rd members removed. It came out to about $200 per hour. For what shops around here charge it would probably cost as much as the truck did.
  3. Nov 6, 2024 at 8:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    Posting in your regional forum may be more valuable
  4. Nov 6, 2024 at 9:33 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I would suggest renting a car if you cannot afford to be without the truck and then doing the swap yourself over those 2-3 weeks. You'll pay big $$$$ for a shop to do this. I'd doubt you walk away paying less than $4k in labor.
  5. Nov 6, 2024 at 12:18 PM
    Hrry4x4
    Hrry4x4 [OP] Member
    Yeah that’s what I’ve been learning since I started calling around. Have you done a frame swap before? I’ve heard conflicting things about the amount of time it takes, strategies, etc
  6. Nov 6, 2024 at 1:08 PM
    Red_03Taco
    Jerad
    I never have done a frame swap, but I just recently did a motor swap (my first one). And in the past I've dropped transmissions, t-cases and drive lines, replaced rear diffs, replaced rear leafs, pulled beds off & done loads of front suspension work.
    So I feel like I've done 90%+ of the individual tasks that would be involved in a frame swap. Doubt I'll ever have to do one though, as I'm in Northern Arizona and rust is really not part of our vernacular down here.
    I'd bet you can get it done with about 50-60 hours of labor. Perhaps more if you're more meticulous about treating the incoming new-to-you frame to prevent future rust issues.
  7. Nov 6, 2024 at 7:23 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    @Tour991 did one in his yard. It can be DIY'd if you have the space and patience.
    Hrry4x4[QUOTED][OP] and Tour991 like this.
  8. Nov 6, 2024 at 8:05 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
  9. Nov 9, 2024 at 6:33 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    is the replacement frame you found Already dismantled and stand-alone part or would that also come into the equation to strip all off before transfer
  10. Nov 10, 2024 at 5:15 AM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    This should help.
