Where to get a fuel tank????
Discussion in '1st Gen. Tacomas (1995-2004)' started by ken14445, Oct 7, 2013.
  1. Oct 7, 2013 at 11:45 AM
    ken14445
    ken14445 [OP] New Member
    kenneth
    Hi,:confused:
    I've been searching for a replacement fuel tank for 2002 tacoma 2.7 xtra-cab 4x4 auto. Why does no aftermarket co. make one??? Does anyone have any tips for a used one? What kind of overlap is there on the application. So far it seems that regular cab tanks wont fit, but 4drs. will? What is the range of what will fit?
    I don't want to spend $450 on a new oem and I've narrowed down the original part numbers down to either 7700104090 and 7700104170. Anyone know the difference between those 2? The online description for both is identical.
    What does someone do when they need a tank??? I'm in rust central in Western NY.
    Thanks for any replies,
    Ken
  2. Jul 8, 2014 at 8:12 AM
    rosst
    rosst Active Member
    gastanksusa.com has one for about $100 less than the OEM offerings
  3. Jul 13, 2014 at 6:44 PM
    MattRRT
    MattRRT Active Member
    Concord, NC
    2009 Tacoma TRD Sport
    Trifold Tonneau Cover, Weathertech window visors, window tint, phone mount
    Ken did you ever find a tank? If so where?
  4. Jul 14, 2014 at 4:37 AM
    ken14445
    kenneth
    Actually, I took the tank out, cleaned it all up and sealed it with ample coverage of "seal-all" sealer. It was quite laborious but I had the time and was unwilling to spend around $500 for the factory tank. So far so good.
    Ken
  5. Jul 14, 2014 at 7:59 AM
    rosst
    rosst Active Member
    I just ordered an oem one from ToyotaParts4Less.com. I thought of going aftermarket in order to save $100 or so, but figured it wasn't worth the hassle if fit and finish wasn't correct. I also ordered a new filler neck as mine is getting a bit crusty.
    I plan to apply POR to the top of the tank and filler neck before installing.
    Hope this ends my evap issues.
  6. Jul 14, 2014 at 8:05 AM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    I haven't checked for the Tacoma, but Napa has been good with fuel tanks on past vehicles.
