Where to Get Chrome Emblems in Smoke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaseyJones, Nov 9, 2013.
  1. Nov 9, 2013 at 11:01 AM
    CaseyJones
    CaseyJones [OP] Active Member
    Toronto
    09 4x4 Dbl Cab TRD Sport
    Looking to de-chromify my truck. I know I can paint but if they are cheap then not worth my time. Looking for front emblem and "Toyota Tacoma" emblems and SR5V6 in smoke grey. Thanks
  2. Nov 9, 2013 at 11:20 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Port Arthur/Lubbock, Tx
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Dont know where you can get them but, honestly, it might be cheaper to paint yourself.
  3. Nov 9, 2013 at 11:29 AM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
  4. Nov 9, 2013 at 11:31 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    2013 DCLB SR5 4X4 Nautical Blue
    Check out my Build
    Dip them... Or paint them..
  5. Nov 9, 2013 at 11:42 AM
    easystickerco
    easystickerco Well-Known Member
    San Diego
    Tacoma SR5
    don't order the cheap ones online, i did from Amazon, the arrived flat black, but even worse they were cheaply made, deformed.
  6. Nov 9, 2013 at 11:45 AM
    CaseyJones
    Toronto
  7. Nov 9, 2013 at 11:54 AM
    teneighty
    Check out my Build
  8. Nov 9, 2013 at 12:19 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Dipped. No removal needed.
  9. Nov 9, 2013 at 12:33 PM
    CaseyJones
    Toronto
    Sorry never heard of the stuff. How would you plastdip without removing??? Also doesn't it peel bad in heat and extreme cold? Thanks.
  10. Nov 9, 2013 at 12:40 PM
    jw1983
    Alberta
    PD is starting to become more popular in Canada now. I only heard of it this past year and started using it. It's usually sold at Home Hardware, Auto Value. I am not too sure about Toronto, you should be able to find it.
    You prep the area. Spray(6 or more coats) it on and leave it. It goes on like paint and dries with a plastic coating. PD was originally used to protect tools. If you don't like it, peel it off. Doesn't wreck the chrome.
  11. Nov 9, 2013 at 12:41 PM
    JdevTac
    JdevTac Negative Ghostrider
    Josh
    GA
    2013 DC TRD-OR 4x4 Pyrite Mica
    The only ones OEM are the X-runner badges and I only think its the tailgate emblems. They aren't too cheap either.
    Example: http://www.tacomaworld.com/forum/2nd-gen-tacomas/115586-black-x-runner-badges.html
    Many threads here on plasti-dip. I've never used it but all you do is mask off the surrounding area, spray it with some good light coats and then you can just peal it off around the lettering and use a toothpick to clean up the rest (areas inside the letters)
  12. Nov 9, 2013 at 2:17 PM
    heavtritefoot
    heavtritefoot Well-Known Member
    ken
    Courtice,Ontario
    Lowes sells it in there paint area. Bought mine in oshawa. Theres tons of clips on how to use it on you tube.
  13. Nov 9, 2013 at 3:12 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    So you've never heard of it.... but then say it peels in heat/cold?
    But no, lots of people here have applied and it if it does peel you can just re-apply. Faster and cheaper than buying new emblems. Folks have used this in Phoenix and Alaska... sure you'll be fine.
  14. Nov 9, 2013 at 7:25 PM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Just by the nature of the description of PlastiDip, a person could easily assume it was susceptible to the elements...
  15. Nov 10, 2013 at 6:30 AM
    CaseyJones
    Toronto
    So for example the centre of the "O" you would just peel off with a toothpick? Is that easy?
  16. Nov 10, 2013 at 7:46 PM
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    the decent black ones form tacoma are not cheap. Just cheaper to do it your self.
  17. Nov 10, 2013 at 8:09 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    I found them on ebay once upon a time... Complete black chrome decal package as a matter of fact.
  18. Nov 10, 2013 at 10:10 PM
    jw1983
    Alberta
    Yeah it's very simple. As long that it's not totally wet and totally dry, it will peel off.
  19. Nov 10, 2013 at 10:16 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Just youtube plasti dip Tacoma badges. I watch the video once and was able to do all the badges on my truck. Just tape the area off and around the badges from spray from the plasti dip. simple and easy. Holds up very well in hot and cold weather and in car washes with brushes.lol
  20. Nov 11, 2013 at 6:09 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2013 DCSB 4X4 TRD Off Road *Sold*
    Plasti-Diped
    $5 dollars at Lowes or Home Depot in the paint section.
    No peeling. Plenty of videos on how to on youtube.
