where to get color matched paint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pgfaulkner, Jul 23, 2009.
  1. Jul 23, 2009 at 11:17 PM
    pgfaulkner
    pgfaulkner [OP] Well-Known Member
    Middleburg fl
    05 Tacoma sport access cab, Metallic black
    So im doing my satoshi and the surround doesnt match my bsp truck. Anyone know where i can get like a half pint or so of bsp paint without paying an arm and a leg. Id prefer to buy the paint and spray(not rattle can) and paint myself because the auto body shops around want an arm and a leg to paint just my grille surround
  2. Jul 24, 2009 at 6:28 PM
    pgfaulkner
    Middleburg fl
    bump, please i need to know and i cant find anything descent on the net. On another note has anyone painted anything on there truck and ordered colormatched paint, if so where from??
  3. Jul 24, 2009 at 6:30 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    just find a local paint shop and have them mix it up for you, a pint will probably only be 20 bucks at most. Google PPG dealers in your area.
  4. Jul 24, 2009 at 6:33 PM
    pgfaulkner
    Middleburg fl
    sorry but what is ppg, and just any old body shop should be able to do it. Im guessing all they need is the color code 209??
  5. Jul 24, 2009 at 6:36 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    PPG is a brand of paint, see if you have a finishmasters in your area...they are a franchise paint dealer and you can have them mix it. If you have some large bodyshops in your area they can mix it also from your paint code if they are willing to sell it to you. Smaller shops might not have a mixing station.
  6. Jul 24, 2009 at 6:41 PM
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
  7. Jul 24, 2009 at 6:43 PM
    pgfaulkner
    Middleburg fl
    thanks but ive been there, its expensive as hell or at least it is to me. over $50 for a half pint seems a bit ridiculous. ill check the local body shops. Any other ideas??
  8. Jul 24, 2009 at 6:45 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    OUCH...they are expensive...80 dollars for a pint is outragous.
  9. Jul 24, 2009 at 6:45 PM
    pgfaulkner
    Middleburg fl
    update there is a finishmasters in my area, anyone know approximately how expensive it will be for what im doing, or had any experience with them
  10. Jul 24, 2009 at 6:46 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Find a local Auto Paint Supplier. PPG I believe is a dealer/commercial only company so you will have difficulties with them. You local Sherwin Williams paint supplier can also point you in the right direction. You can also order it from Toyota. If you live in a fairly large town you shouldn't have to many problems. I went to my local Sherwin Williams Automotive Paint Dealer and got two quarts of BSP. I had one quart made into rattle cans. It didn't cost me to much.
  11. Jul 24, 2009 at 6:47 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    call finishmaster on monday
    9800 Beach Blvd.
    Jacksonville , FL 32246
    (904)642-0902
    1927 Cassat Avenue
    Jacksonville , FL 32210
    (904)389-3517
  12. Jul 24, 2009 at 6:49 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    PPG is just a brand...finishmasters carries them, as well as local paint shops will...all the paintshops in my city will sell to the public however there is a little bit more markup on the paint/supplies. Reason i know...i used to work for one. :)
  13. Jul 24, 2009 at 7:03 PM
    pgfaulkner
    Middleburg fl
    just what i needed to know
