Where to Get Gear Oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bwise, Aug 1, 2025 at 7:10 PM.
  1. Aug 2, 2025 at 9:05 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Just to correct your misconception, Toyota does not call out either GL-5 or GL-4 in the owner's manual. Look under Specifications section 8-1, it asks for LF. The additive in GL-5 would be wrong for the transfer case. My understanding (haven't yet opened my xcase) is there is a brass part in the case that should not be exposed to the GL-5 additive.
    There are those who say it really doesn't matter at all, but since you were asking and seemed like you wanted to do a "correct" job.
    STEELeR43 and joba27n like this.
  2. Aug 2, 2025 at 9:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just like mom used to make
    Phlogiston[QUOTED] likes this.
  3. Aug 2, 2025 at 9:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  4. Aug 3, 2025 at 4:07 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Unless he got the info direct from whoever makes this for Toyota, GL5 doesn't make sense but maybe it is. Good luck finding aftermarket 75w GL5 oil though.
  5. Aug 3, 2025 at 4:10 AM
    bwise
    bwise [OP] Well-Known Member
    Car care nut is a master tech on YouTube. Dude has absolute baller info on Toyota maintenance that’s where I heard using GL-5 in the t-case. He also said throw 75W-90 in everything and you should be good.
    Some people on this thread said GL-4.
    My owners manual did not specify a GL rating.
    Due to all this conflicting information I decided the best route was to get the OEM stuff for the t-case and rest easy.
    Smacky2020 likes this.
  6. Aug 3, 2025 at 6:43 AM
    Cleetus
    Cleetus Member
    FL
    25 Sport Prem.
    gl5 for the diffs
    gl4 tcase (brass syncos)
    I run Mobile1 delvac 75-90 diffs (if LS additive is not required)
    redline 70-75 tcase
    been doing this for 10+ years
  7. Aug 3, 2025 at 10:35 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
