Where to get this bushing...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 762x51taco, May 7, 2011.
  1. May 7, 2011 at 3:43 PM
    762x51taco
    762x51taco [OP] Well-Known Member
    I bought this truck with a ULK lift already on it, and today I notice that the (tie rod??) bushing is shot due to an extreme angle. Do I need to replace this, and if so where do I find it?
    Can I bust the lock nut and turn the TR to make the angle less extreme without an ill effects? The drive side aint too bad, but the passenger side is pretty messed up. Thanks :)
    Driver
    Passenger
  2. May 7, 2011 at 3:50 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    No, you need new tie rod ends and then an alignment, Im in the same boat
  3. May 7, 2011 at 3:53 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    Probably better off replacing the whole tie rod end.
  4. May 7, 2011 at 3:58 PM
    762x51taco
    Sounds good, ill search for a good brand. Does this need to happen ASAP or can I wait it out a bit?
  5. May 7, 2011 at 4:04 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    The longer you wait the worse it'll get. TRE's aren't to expensive.
  6. May 7, 2011 at 4:07 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Jack up the front of the truck enough to get the tires off the ground. Then while facing the tire put your hands at 9 o'clock and 4 o'clock and wiggle the tire left and right. If there is play, moves easily before pushing the other tire, then yes replace them. When you get alot of play the tie-rod can separate from the "cup" it's in and fall out, scary when on the highway. Once they are both replaced get an alignment ASAP.
    A good brand is MOOG which is an aftermarket brand sold at many stores.
  7. May 7, 2011 at 4:09 PM
    762x51taco
    Will I need just the outer, or will/should I do the inner as well? If its just the outer I assume I just take the thread count, disconnect, reinstall new one to the old thread count and I should be GTG?
  8. May 7, 2011 at 4:14 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    You should be good with just the outer, mark the position on the threads before removing it for reference when installin the new one.
  9. May 7, 2011 at 4:17 PM
    762x51taco
    Perfect, thanks for the help, will order tonight.
  10. May 7, 2011 at 10:59 PM
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    When replacing tie rod energy suspension has replacement boots that do not wear out like stock ones. I have used them bfore
  11. May 8, 2011 at 5:25 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The boot's only use is to keep dirt out of the joint and the factory grease in. It has nothing to do with actual functioning of the actual tie rod. So being torn isn't itself a problem.
    I've driven thousands of miles with bad tie rod end boots... the TRE never got so loose as to be a problem. If you off road a lot yours will prolly go faster, but you don't have to hop on it until you notice looseness.
