Where to go for tire install?
Discussion in 'Wheels & Tires' started by sixdoubleseven, Dec 26, 2010.
  1. Dec 26, 2010 at 11:20 AM
    sixdoubleseven
    sixdoubleseven [OP] Wrangler Convert
    Dave
    Boston
    2014 DC 4x4 Pyrite SR5
    Just picked up some new tires form a member on here. Can anyone recommend a shop south of Boston to do the install?
    Should I go to the gas station down the road? Should I have NTB or Direct Tire install? Noticed Walmart Tire Center will do the install for $5 per tire, though the nearest one is 40 miles away.
    Thanks
    Dave
  2. Dec 26, 2010 at 4:54 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    well,if you trust the gas station down the road,go there.
  3. Dec 26, 2010 at 5:03 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I'd personally pass on a gas station or wallmart...go to either a regular tire shop or the dealer. They have better equipment to make sure everything gets done correctly. The tpms sensors on our trucks can get broke easy and you'll want a shop that knows what their doing and will stand behind their work incase of a problem. Don't forget to check the lug nuts before you leave!
