Where To Go From Here: A million ideas but not a million dollars
Discussion in '1st Gen. Tacomas (1995-2004)' started by DFD1994, May 19, 2013.
What is your opinion on my desired setup?
  1. Do it all, but over time
    2 vote(s)
    18.2%
  2. Do it all, save and wait until you can do it all in one swoop
    2 vote(s)
    18.2%
  3. Some of this stuff isn't doable/some of it is too difficult to DIY
    0 vote(s)
    0.0%
  4. You shouldn't want to do any of this/it is needless
    7 vote(s)
    63.6%
  1. May 19, 2013 at 8:05 PM
    DFD1994
    DFD1994 [OP] Member
    Dallas, Texas
    2000 PreRunner 4Cylinder
    JVC Head Unit, Polk Audio DB651s Speakers
    Alright here goes my breakdown:
    I have been a member for awhile now and I decided it was about time to make this post I have had written up for awhile since I just graduated from high school and this summer will be the best chance for me to get some (I wish it was all) of what I have dreamed up for my little truck. If you know of a place where I can find products or instructions that could assist me in accomplishing this I would greatly appreciate it as I have dug around for a month without any definite answers.
    What I have dreamed up:
    1. I want to remove my jump seats a build/purchase a cabinet setup that could turn the space behind the front seats into more useable storage space.
    2. I already have an emergency light bar in my rear and front window and would like to install another set of strobes on a front brush guard. Has anyone found a best value for a simpler brush guard since I want it more as a mounting point (little pre-runners don't have too much off road fun) Also, what is the best cable path from my cab switch to the front bumper?
    3. Also in addition to my other emergency lighting I need/want a light bar mounted on the exterior above the truck's sight line on a headache rack, what is the best cable path to get out the rear of the cab and what have y'all used to cover the exterior portion of the cable run.
    4. Along with my light bar I have been considering a GoLight remote searchlight and wanted to know if anyone has used this brand and what the best combo is as far as their wired and wireless controls as well as mounting options that they offer.
    5. As if this wasn't enough I have also wanted to do some more "regular" mods such as swapping out for after market LED head and tail lights along with LED dash and A/C panel lights to match my stereo's LED face plate and if it is not too much trouble add an LED dome light too.
    This is everything I want to accomplish plus the actual installation of a headache rack so obviously there has to be an order to things, plus some things are much more doable given my current financial ties to college. Any help or links is greatly appreciated.
  2. May 19, 2013 at 11:35 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    First of all, whats your budget and what's it going to cost you on paper....
    Two... why so much lighting?
    Three. Why a headache rack? Are you carrying heavy, shifting loads in the bed?
    I wouldn't go Brush Guard... they're heavy, ugly and weak. I'd go for a low profile Trail Gear bumper with light hoop. _MG_4123_d78addca04b26065b88f666cfde119f9ef4eaea1.jpg
  3. May 20, 2013 at 4:12 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I smell a whacker -_-
  4. May 20, 2013 at 6:54 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    As for your wiring questions... There's a rubber grommet in your driver side footwell above the pedals. I think there's one on the passenger side too, but I know for sure it's on the driver side. You might have to slice it a little bit with a knife the first time you use it (or maybe not, I did but I was running 0 gauge amp power wire) and it's pretty easy to feed wire through it using a coat hanger or something similar. In the back there's another grommet in the floor of the cab in the driver side storage compartment thing under the jump seat on that side.
    Are you an EMT or firefighter or something? Why so much lights?
  5. May 20, 2013 at 7:17 AM
    Blindsider
    Blindsider Well-Known Member
    Craig
    Upstate NY
    18 DCLB TRD OR
    Are you building a zombie apocalypse Tacoma alla I Am Legend?
  6. May 20, 2013 at 7:49 AM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    ^^^ agree
  7. May 20, 2013 at 1:29 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    My question is, "What do you plan to do with your truck?" Your mods should match your intended use for your rig.
  8. May 20, 2013 at 3:24 PM
    DFD1994
    DFD1994 [OP] Member
    Dallas, Texas
    I appreciate the replies, except the accusation of a whacker... not sure on that. As to my intent, I wanted to do the LED swaps inside the truck (panel and dome lights) just because I prefer the look, the amber strobes are because I am a fire photographer and my truck often gets lost on scene, the setup I have now plus what I have preposed would actually make me visible. As for the headache rack I tend to do hauling of tools and mowers and such that have scratched the top lip of my cab in the past, fixed it once and I don't want to touch it up a second time. Storage in the truck is my first priority right now since I want to get that all sorted out and build the unit if need be over this summer.
  9. May 21, 2013 at 7:30 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
  10. May 21, 2013 at 8:02 PM
    DFD1994
    DFD1994 [OP] Member
    Dallas, Texas
    honestly not too far from the truth Box Rocket
