Where to locate a Mobile Unit (Ham Radio)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Apr 6, 2016.
  1. Apr 6, 2016 at 12:11 PM
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I've got a Kenwood TM-241A.... Not a detachable face model. I'm looking for a nice way to install this in the truck. Anyone got some good ideas? Post pictures please!!!
    I'm not sure I want to break down and buy another mobile unit with a detachable face.
  2. Apr 6, 2016 at 12:24 PM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    That's really the rub right there though, isn't it? Maybe on the passenger side of the trans tunnel, like people often do with CBs. I've got an ICOM 2730a that needs to go in at some point, but I'm really going back and forth constantly about where I'm going to put the head.
  3. Apr 6, 2016 at 12:31 PM
    Derek G
    Derek G Well-Known Member
    Silverton CO
    2016 TRD OR DC
    I was looking at the same issue. I'm just going to get one with a detachable face plate though and even then finding a good spot might be challenging
  4. Apr 6, 2016 at 12:32 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    detachable face between the sunroof and the mts/cc system seems like a good place
  5. Apr 6, 2016 at 12:34 PM
    Derek G
    Silverton CO
    2016 TRD OR DC
    My Switch Pros control box is going there.
  6. Apr 6, 2016 at 12:56 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    all the switches I will use I'll mount where that little useless cubby hole is the left of the steering wheel.
  7. Apr 6, 2016 at 12:58 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    I was looking at that particular unit. Is it a good unit? I was also looking at picking up a 706 MKIIG, but getting a new-in-box is difficult and a bit expensive so the ft857 might be in order.
  8. Apr 6, 2016 at 1:04 PM
    forty2
    Cascadia
    2016 DCSB OR 6MT
    I haven't actually used it yet, been sitting in the box in the corner of my shop for the last 8 months. Just getting by with my HT until I get around to install. I really like the size and configuration of the head, plug on the back instead of the side is nice for keeping things hidden and mic from head or radio is cool. Pretty sure I'm going to mount in the space between the sunroof and map lights/roof controls. I think the head is just small enough for that space, I just need to sack up, pull the headliner, and start cutting into it.
    As to the 2m/440/HF, I only have my tech ticket and I haven't put a lot of thought into upgrading to general. Maybe someday.
  9. Apr 6, 2016 at 2:19 PM
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    I have seen some different radio installs into the center console, looks like a PITA to install. But if your on to 2m you know you gotta have it. I like the 241a because you can receive only in the marine band I believe...gotta a be some new radio gear out nowadays...
  10. Apr 6, 2016 at 2:20 PM
    arkywally
    David
    2016 DCSB TRDOR
    Why not just get a good mobile?
  11. Apr 6, 2016 at 5:02 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    the 2730 appears to be a solid dually from what I have read, however if im gonna spend 4-500.00 on a dual might as well go for the all-mode uhf/vhf/hf setup and do it once and be done.
  12. Apr 6, 2016 at 6:42 PM
    Woodrow F Call
    Colorful Colorado
    The Yaseu FT-8900R can be had for $329, but I have the Kenwood.
