Where to mount gps antenna?
Discussion in 'Audio & Video' started by toemoss, Jul 15, 2010.
  1. Jul 15, 2010 at 6:56 AM
    toemoss
    toemoss [OP] Member
    Thomas
    Iowa
    06 4x4 TRD Sport doublecab
    I bought a gps reciver off ebay and it came with no instructions. I found all the wiring diagrams I needed online but my google fu is no good and I cannot figure out where I am supposed to mount the antenna for the gps. It has bout 6-7' of cable and a magnetic mount. Under the hood ? On the Dash ? Behind the dash? Model -ECLIPSE AVN2210P
  2. Jul 15, 2010 at 7:11 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    I ran my antenna to the right of the head unit behind the glove box and pushed the wire in snug until I only had the little box showing rim the farthest right hand corner of the dash. I didn even tape it down, it isn't going anywhere and the signal is great on my AVN726
  3. Jul 15, 2010 at 7:32 AM
    Nikwanchoo
    Nikwanchoo Well-Known Member
    Florida
    TRD Sport 4x4 DC SB
    hendooman's idea looks pretty good. The directions for my AVN726e said to place it 20 or so inches from the head unit. I ran the connector end through the top of the defroster vent holes in the center area of the dash and used my other hand to reach behind the head unit area and catch the wire. I had to fold back the edge of the defroster compartment as it met the underside of the dash. It might be a little hard if you have large hands. Anyway, my antenna isnt the required 20 inches away from the unit but i still have perfect satellite signal. I would have liked to route it behind the driver side dash, that way it would have been completely hidden from view, but it would have been harder...for me at least.
  4. Jul 15, 2010 at 8:54 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Mine is under the dash.
  5. Jul 15, 2010 at 9:04 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I have a Kenwood DNX6960 and ran my antenna cable under the dash to the left. I took off the plastic cover on the left window frame upright and just put the wire through there with plenty of space. Put the cover back on the upright and then just let the antenna rest in the corner. Maybe a little double sided tape to keep the car wash nazis from tearing it up but that's about it and I get great signal all the time.
  6. Jul 15, 2010 at 2:21 PM
    TacoPorn
    TacoPorn Well-Known Member
    California
    08 PreRunner SR5
    I just put mine in last week right above the head unit bit under the dash. Just use some Velcro. My signal is always strong.
  7. Jul 16, 2010 at 6:05 AM
    Rusty White Taco
    Rusty White Taco Active Member
    Central Coast, CA
    04 4x4 Xtra Cab TRD Offroad SR5
    Debadged, Front 5100s at 2.5, 1" rear shackle lift, 5125s in the rear, trimmed exhaust pipe
    ^^ x2
    I've had my GPS antenna above the radio under the plastic dash for 2 years now and it works perfectly. I've never had any issue "seeing" any satellites.
  8. Jul 18, 2010 at 11:00 AM
    pcm888usa
    pcm888usa Member
    CA
    06 PreRunner SR5 V6
    TRD Exhaust, Clarion NX500 Nav/Radio, ERB Slotted front disc brake and pads
    I ran the wire through the firewall into the engine compartment and then route it to the top of the front hood. It is hidden nicely behind the hood protector.:)
