Where to mount killswitch?
Discussion in 'Technical Chat' started by YeahYeah, Jul 25, 2010.
  1. Jul 25, 2010 at 11:10 PM
    YeahYeah
    YeahYeah [OP] Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    I have already mounted my killswitch for my ignition but its in the most obvious place... the little drawer on the left next to ur knee. Where else would be a great place to mount it that no one would know(except all you responding to this):rolleyes:
  2. Jul 25, 2010 at 11:12 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    in side the center console,
  3. Jul 25, 2010 at 11:13 PM
    YeahYeah
    Thomas
    would that be too obvious?
  4. Jul 25, 2010 at 11:16 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    idk how 2nd gen ones are but not in a 1st gen.
    how about like under your seat or someplace like that
  5. Jul 25, 2010 at 11:17 PM
    YeahYeah
    Thomas
    oooooooooo! genius! sheer genius.
  6. Jul 25, 2010 at 11:17 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    maybe on the inside of the dash like next to the obd-II port
  7. Jul 25, 2010 at 11:18 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Pardon me asking, but what exactly is a killswitch? Sounds self-explanatory, but I've never heard of this.
  8. Jul 25, 2010 at 11:20 PM
    YeahYeah
    Thomas
    Kill Switch Mod Write Up. type this in up in the search bar. easy mod, great idea. it kills the flow of the current when you try to turn your car over.
  9. Jul 25, 2010 at 11:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Get a floor mounted dimmer switch like in older cars and trucks. Mount it under the dash out of site, but still where you can reach it with your foot.
  10. Jul 25, 2010 at 11:24 PM
    YeahYeah
    Thomas
    a dimmer switch? as in the kind that dim the panels? how does that work:eek:
  11. Jul 25, 2010 at 11:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    In older vehicles, the switch that controls the change from high to low beams was mounted on the floor. You used your left foot to switch back and forth. I know that Ford trucks up to 1991 had them on the floor.
    Basically it's just a single pole double throw switch designed to be switched with your foot. They're like $10 at NAPA. You would only need two of the three terminals to use it as a kill switch. You might also need the connector that goes with it.
  12. Jul 25, 2010 at 11:32 PM
    YeahYeah
    Thomas
    not a bad idea at all! keep em coming!!!
  13. Jul 25, 2010 at 11:33 PM
    The_Dude
    The_Dude Well-Known Member
    If it's a stick you could mount a button under the boot on the shifter?
  14. Jul 25, 2010 at 11:34 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    my vote is trunk monkey
    okay its like230 am my ass is goin to bed before i get in trouble
  15. Jul 25, 2010 at 11:34 PM
    YeahYeah
    Thomas
    na, no stick. only on my 92 4runner. ill have to do that one to my 4runner
  16. Jul 26, 2010 at 12:32 AM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Get a factory style switch that will go in your dash. Example would be like the e-locker switch(came factory on some but not on all), wire that up as a kill switch. It would look factory and you dont have to lean down or more around to make it obvious that you have a kill switch.
    Edit:
    Or a key fob where a magnet or something on your keys has to be within 5ft of your truck.
  17. Jul 26, 2010 at 12:35 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    good idea! I may use that.
  18. Jul 27, 2010 at 7:46 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    have you thought about putting one in the back of the truck like they do on race cars? If you're injured or unable to get out of the truck, your buddy could shut it down from the outside.
  19. Jul 27, 2010 at 7:47 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    If you could fit it in there, I'd say right behind the steering wheel.
    It's really easy to access for daily use, and almost undetectable to the naked eye.
