where to mount winch solenoid
Discussion in 'Garage / Workshop' started by fireturk41, Jul 25, 2010.
  1. Jul 25, 2010 at 10:19 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i bout a warn m8000 winch i have the winch mounted on the bumper but cant find a good place to mount the solenoid, where do yall have your solenoids mounted i need ideas
  2. Jul 25, 2010 at 10:20 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    put it under the hood on the pass. side wheel well
  3. Jul 25, 2010 at 10:29 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i tried but my issue is then the short ass wires wont reach the winch it self.
    you think i could get the same guage wire and solder the two to extend it with out breaking any kinda warrenty rules?
  4. Jul 25, 2010 at 10:34 PM
    JimBeam
    JB
    2015 Tundra
    i would think you should be able to
    crack the winch open and replace the wires completely instead of soldering them together
  5. Jul 25, 2010 at 10:39 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    its the ones in the solenoid that wont reach, they make it a really long hot and ground but everything else is about 8" haha
    it looks about 4 guage, ill see if i can crack it open and find some new wire for it while im out shopping tomorrow
  6. Jul 25, 2010 at 10:40 PM
    JimBeam
    JB
    2015 Tundra
    thats what i would do personally
  7. Jul 25, 2010 at 10:41 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    haha i cant sleep so i may try to crack it open now
  8. Jul 25, 2010 at 10:46 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    wow...the wiring in there is so simple it aint funny, the only thing i cant remove is the motor ground
  9. Jul 25, 2010 at 11:13 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I found some replacement battery cables that had the right ends on it and long enough to reach.
  10. Jul 25, 2010 at 11:14 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    just the kind youd pick up from somewhere like autozone?
  11. Jul 26, 2010 at 2:27 AM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    yep. Nothing special about the wire except to make sure you get the ring ends on both sides. I just used the same gauge wire that came with the main power line (4 gauge?), which the majority of battery cables are made of.
    As for length, I took a string, ran it the route I planned to take it and measured. Make sure to give yourself extra since 4 gauge isn't nearly as flexible and quite a lot thicker than string.
    For mounting, I just drilled two holes in the wheel well and tightened it up with some washers and lock washers. Just used the two bolts that are on the solenoid pack.
