Where to order new trans filter & gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_Tacoma, Dec 9, 2010.
  1. Dec 9, 2010 at 7:03 AM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    going to drop the 2005 transmission pan and change the fluid, gasket and put back.
    where have you ordered the gasket material?
    Toyota told me they reuse the filters, I kind of like putting a new one in, makes more sense....right....
    any information will help and be appreciated. either way i am taking it down....
  2. Dec 9, 2010 at 7:08 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  3. Dec 9, 2010 at 7:37 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    First, it's not actually a filter, it's a strainer (screen mesh). Second, there is a procedure to follow for the tranny that's in the 4.0l (assuming that's what you have). It may be the same for the 2.7l tranny. Basically, if you don't have a fill tube/dip stick, you need to follow the procedure.
  4. Dec 9, 2010 at 7:43 AM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    I have 5 speed auto, v6 prerunner.
    yea I have found some filters but toy says they just wash the screen off and reuse. I guess this is the best........
    I found the procedure about how to drain and fill....
    I am going to drop the pan, inspect the filter, and oil. put new gasket on and reinstall. then fill using the jumper wire tech for the tempt reading.
    I tow a 5,000 pound travel trailer and its not just the weight, but the wind drag on the box shape that puts a bit of pressure on the truck...the trany is starting to shimmy, slip or something at take off in any gear. nothing with out the trailer behind it.....I am not sure...
    if i can't some how solve it here. and i can't get beefier heavy duty parts for it, she is gone............GMC 3/4 here i come.....
