Where to Place the OME Trim Packer
Discussion in 'Suspension' started by NicksRig, Oct 15, 2009.
  1. Oct 15, 2009 at 7:03 AM
    NicksRig
    NicksRig [OP] Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    LIke the title says. Do I place it under the top plate above the spring? Or on top with the spacer? I am taking OME stuff to the shop to be built this morning and I want to make sure these guys do it right.
  2. Oct 15, 2009 at 7:14 AM
    PPD934
    PPD934 Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    i am not totally for sure But i think it does not go in the assembly. I think is like the smaller spacer on the spacer lift it just sits on top of the assembly
  3. Oct 15, 2009 at 7:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It goes inbetween the lower spring seat, and the spring seat mount on the shock. Say your holding the schock, shaft pointing UP. Slide the Trim packer on the shock, then the black spring seat.
  4. Oct 15, 2009 at 7:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Though this is a pic of the passenger side It goes inbetween the spring seat and the shock as in this pic
  5. Oct 15, 2009 at 7:24 AM
    NicksRig
    Kenora, Ontario
    Thanks Chris.
  6. Oct 15, 2009 at 7:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Oct 15, 2009 at 7:24 AM
    PPD934
    Western Kentucky
    hey chris for the 3 inch lift, looking at the toytec page do i need to order the 885 ciols with the top plate spacers or just the 885 coils. Also does the top plate spacer take palce of the trim packer or is it something different
  8. Oct 15, 2009 at 7:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The trim packer adds 5mm lift to the driver side (= 10mm) to account for the lean. The top plate spacers are "lift enhancers". FWIW, you may want to order the 885's from Wheelers, as I have heard of some of the OME springs from Toytec sagging. They may have some old stock lying around. But, Yes. The 885's give 2.5 to 3" lift.
