Where to put aux fuse panel on supercharged Taco?
Discussion in 'Lighting' started by keaton1991, Jun 14, 2014.
  1. Jun 14, 2014 at 10:13 AM
    keaton1991
    keaton1991 [OP] Well-Known Member
    Brian
    Dallas
    12 Pyrite DBL Cab Long Bed
    Icon 2.5 remote resi's front and desert racing A-arms, Icon 2.0 resi's with deaver leaf pack with POly bushings. Softopper
    I got everything lined up for wiring lights to blue sea and panel for non atrac truck and theres a pump that connects to the intercooler i missed. Any ideas for another place to mount?
  2. Jun 14, 2014 at 10:14 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Check on the pass side there is a big opening. Another option that some guys take is to make a small bracket that hovers over the fuse panel.
  3. Jun 14, 2014 at 10:16 AM
    keaton1991
    Brian
    Dallas
    Thanks, I think I'll try to make a panel that will hover over the stock fuse box. Is there any need to access the original fuse box other than an issue?
  4. Jun 14, 2014 at 10:29 AM
    memario1214
    Colton
    Missoula, MT
    Well no... not really. That intercooler fuse is pretty janky so I find myself in there every few months. Just make sure to keep the right too in your truck to remove it in case of emergency.
  5. Jun 14, 2014 at 10:35 AM
    keaton1991
    Brian
    Dallas
    Theres a bolt holding rubber fuse box bracket and negative battery ground, is this safe to use for the panel to mount to?
  6. Jun 14, 2014 at 10:41 AM
    memario1214
    Colton
    Missoula, MT
    Trying to picture it in my head... Is that down on the wheel well or up the side where the fender rolls up?
  7. Jun 14, 2014 at 10:42 AM
    double dee
    double dee Well-Known Member
    Arizona
    here is another members set up
  8. Jun 14, 2014 at 10:46 AM
    memario1214
    Colton
    Missoula, MT
    Aaand Derrick has the real answer because I don't have the drive to do a search on my phone. Thanks mang!
  9. Jun 14, 2014 at 2:03 PM
    keaton1991
    Brian
    Dallas
    Thanks guys, I'm going to go with that picture setup.
