Where to put firewall grommet for wiring
Discussion in '1st Gen. Tacomas (1995-2004)' started by alphabravo, Feb 27, 2015.
  1. Feb 27, 2015 at 10:24 PM
    alphabravo
    alphabravo [OP] Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I'm will be putting some carling switches in and I'm wondering how you guys pass through the firewall. Is there a grommet kit and a good spot for it?
    TIA
  2. Feb 28, 2015 at 7:23 AM
    copacetic1
    copacetic1 Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    There is a hole in the firewall already with grommet behind the fusebox, you should be able to use that.
  3. Feb 28, 2015 at 7:36 AM
    Madjik_Man
    Colorado Front Range
    There's also one on the passenger side
  4. Feb 28, 2015 at 12:44 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    nice. thanks.
