Where to route signal cable and turn on lead?
Discussion in 'Audio & Video' started by Blaise22, Jun 11, 2009.
  1. Jun 11, 2009 at 8:11 PM
    Blaise22
    Blaise22 [OP] Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    Im going to put my amp under the driver seat with the power cable on the left side of the truck straight to the amp. My first plan was to route the sinal cable and turn on lead on the right side and crossover under the rear access cab carpet, under the driver seat and into the amp. That looked pretty hard so do you think i can just route these wires to the left of the head unit, through the center consol and down under the seat without getting any interference or is that to close? How far apart does the power wire and the signal cable have to be in order to get no interference? Sorry if thats confusing, thanks for the help;)
  2. Jun 11, 2009 at 8:36 PM
    blacksandtaco
    blacksandtaco Well-Known Member
    Tyler
    Kansas
    07 Access TRD Sport 4X4
    Viper remote start/alarm, Kenwood Excelon DNX 9140 in -dash Nav and DVD, Anzo black headlight, FoldaCover tonneau cover, BedRug carpeted truck bed, Pop-A-Lock electric tailgate lock, Level 8 MK6 (16x8), Toyo Open Country AT2 (LT265/75R16), Fold-A-Cover Tonneau, Bilstein 5100s front, Rear Leaf Suspension TSB, AVS in-channel front window vents, AVS Aeroskin hood protector,
    I wouldn't do it but that's just me. I would stay as far away from the power wire as possible, especially if you are using thick power wire. I absolutely hate engine noise and other interferences.
  3. Jun 11, 2009 at 8:38 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    i think you'll be fine routing the power down the left and others down the center...
  4. Jun 12, 2009 at 8:34 AM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    Your grounding point is more important than where you route your wiring. Make sure you get it cleaned off to bare metal and make a solid connection.
    Too many times I've seen the "power wire is too close to the rca's" problem, yet the connections are hideous. But they blamed it on that. :rolleyes:
    I've run them next to each other many times with zero interference. Good connections and good wire/cabling is a must.
  5. Jun 12, 2009 at 8:58 AM
    Octane151
    Octane151 Well-Known Member
    Virginia Beach
    2009 4WD DC LB Silver
    Bilstein 5100 3" lift, Viper SmartStart, Pioneer AVIC-Z140, XM, Licence plate cam, PAC steering wheel control, ID XS65's, ID CTX65's, IDQ10 D4v3, Alpine PDX-4.100, Alpine PDX-1.600, Custom amp board and sub box, 3M Tint, step bars, BHLM Projector coversion w/ 5Ks, Redline hood struts, Weathertech Digital floor mats, hardshell bed cover
    I agree with GoBlueFan on this... I have my left speakers and tweeter wire running next to a zero gauge power wire, and the sound output is still crystal clear. I'm using nice thick Tsunami wire, and I sanded the crap out of the spot where I grounded my amps. Do it right the first time with good equipment, and you'll have clean sound, no doubt.
  6. Jun 12, 2009 at 9:18 AM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    most of the myth issues relate to the RCA's and power wire. In the past, with crap RCA's and poor grounding on either the radio, or the amp itself (or any other number of components for that matter), you could get some engine noise. 9 out of 10 times, it's going to be a grounding issue somewhere.
  7. Jun 12, 2009 at 10:57 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i ran mine down the center consol, under the shifter.
  8. Jun 12, 2009 at 1:23 PM
    Blaise22
    Blaise
    California
    awsome thanks guys for all the help. Is there a good spot under the driver seat to put my ground wire?
  9. Jun 12, 2009 at 2:07 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    I use the seatbelt mounting bolts for my grounds if possible. Just have to make sure you get a large enough ring terminal for the bolt to go through.
  10. Jun 12, 2009 at 3:21 PM
    Blaise22
    Blaise
    California
    perfect thank you:thumbsup:
  11. Jun 13, 2009 at 12:01 PM
    Blaise22
    Blaise
    California
    Should I put the ring directly behind the bolt, or should it be touching the bare metal mounting bracket that its all attached to.
  12. Jun 13, 2009 at 6:25 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    bare metal
    There are also several unused M10 bolt holes with threaded insert under your console. I am in the process right now of installing my stuff and that is where I'm going to ground at. Just strip the paint and you'll have a super easy, great place to ground.
