Where to route solar panel wires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Oct 4, 2018.
  1. Oct 4, 2018 at 9:53 AM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Recently installed a renogy 100w panel on my cab rack. Probably going to install the controller in the cab on trans tunnel near feet on pass side.
    Any thoughts on how to run wires to controller and battery? So far am thinking to drill out a body plug in the floor and then seal around the wires with gasket material...
    johntoyota, kgilly and sd1uh8as like this.
  2. Oct 4, 2018 at 10:01 AM
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    I took mine down between cab and bed, all the way forward into engine compartment and then through the port in the firewall. This kept me from having to drill anything.
    Can I ask where you got the adjustable arms? Mine is mounted flat but I would love a set of those.
    synaps3 and oconnor like this.
  3. Oct 4, 2018 at 11:20 AM
    Rujack
    Any chance of a pic of firewall routing? I already have a few added things running through the firewall but I went through a pretty small opening - probably ~1/2” hole where a plug was. Didn’t see much else other than where the oe harness goes through, but don’t want to modify that one...
    I made them out of 1.5” and 3/4” aluminum angle.
    Edit: they aren’t actually adjustable. At least not on the fly. I plan to make them adjustable when I have time. Thinking I may just go with small gas struts and some latching device to hold it down when laying flat.
    BigRus75 and OnHartung'sRoad like this.
  4. Oct 4, 2018 at 11:22 AM
    TSki
    Tyler
    Salmon, Idaho
    It’s dark here (Germany) but I will snap a picture tomorrow.
  5. Oct 4, 2018 at 11:24 AM
    Rujack
    Danke!
  6. Oct 4, 2018 at 11:24 AM
    Panhill
    Panhill Member
    Adam
    Amazing set up, where did you pick up the solar panel from?
  7. Oct 4, 2018 at 11:26 AM
    Rujack
    Amazon, naturally!
    Got a damaged package but like new discount for a kit w controller for $160
  8. Oct 4, 2018 at 11:27 AM
    Panhill
    Panhill Member
    Adam
    Crazy good deal you got there.
    I am very interested in solar electricity, thank you for posting !!!
  9. Oct 4, 2018 at 11:56 AM
    skig0d
    skig0d Member
  10. Oct 4, 2018 at 12:06 PM
    skig0d
    skig0d Member
    From the firewall - routing up the C post:
    Pulled back the headliner (didn't have to remove) and went through the roof:
    BigRus75 likes this.
  11. Oct 4, 2018 at 12:08 PM
    RevivalOL
    RevivalOL Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    You can go through the vent in the rear wall of the cab as well. Pull the plastic behind the seats out and you’ll see it. I ran my cb antenna through there for over a year with no issues. Keeps you from having to drill anything.
    oconnor and OnHartung'sRoad like this.
  12. Oct 4, 2018 at 4:49 PM
    Khonception
    Khonception Well-Known Member
    Khon
    Ft worth Tx
    17 DC OR/13 DC/08 DC OR
    Since i had no use for my shark fin antenna. I ran mine through there.
    And ran the solar wires along the driver side door sills to engine bay.
  13. Oct 4, 2018 at 5:45 PM
    Rujack
    Looks good but no way I’m ready to cut into my cab lol!!
    gsubioguy and kgilly like this.
  14. Oct 4, 2018 at 8:25 PM
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    You can run wires down between the bed and cab, then bring it back in through one of the rubber plugs in the floor. I did this for the wire for the pop lock in the tailgate. I had to connect the power wire to the rear door actuator. I would then use some silicone around the wire to ensure a watertight seal.
  15. Feb 4, 2019 at 8:25 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Question for @skigOD and @Khonception[/USER] (yall seem familiar with solar setups) or anybody that knows. I have a fuse box in the back end of my bed that I ran to have a direct source of 12v power from my secondary battery. I have a 4 gauge wire going directly to the second battery but I ran my ground down to one of the rear bumper bolts. I thought about connecting my charge controller directly to those wires as that way I would not have to have the setup leave my camper shell area. I am wondering though if the charge controller needs to actually go to the battery, or if simply being grounded is sufficient. Thoughts? Does my explanation make sense?
  16. Feb 4, 2019 at 12:40 PM
    RESQMAN
    RESQMAN Well-Known Member
    2018 White DC LB TRD Off Road
    You want to run your charge controller directly to the battery posts. Technically, it may work the way you said, but it's not best practice
  17. Feb 4, 2019 at 12:43 PM
    RESQMAN
    Looks similar!
    BigRus75 and Rujack[QUOTED][OP] like this.
  18. Feb 4, 2019 at 12:48 PM
    johntoyota
    Down yonder in TN
    16 truck
    Ive been asking in another post as well. I think I have decided to run another 4 gauge all the way to the battery for the ground. Effectively, this is the same as going from charge controller to the battery in my mind as the wires do go directly to the battery. Am I wrong?
  19. Feb 4, 2019 at 1:09 PM
    RESQMAN
    You want the wires from the controller direct to the battery with a fuse in between rated equal to your charge controller, keeping the cables as short as possible.
  20. Feb 4, 2019 at 1:12 PM
    johntoyota
    Down yonder in TN
    16 truck
    Not being difficult, but what is the difference in a small wire leaving the controller going to the battery versus a small wire leaving the controller going to a large wire that then goes directly to the battery?
