Where to route solar panel wires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Oct 4, 2018.
  1. Feb 4, 2019 at 1:20 PM
    RESQMAN
    RESQMAN Well-Known Member
    2018 White DC LB TRD Off Road
    Not saying there isn't more than one way to skin a cat, just make sure you have the proper rated fuses in the right spots. You want one between your panels and the controller, one between the controller and battery, and one between the battery and the inverter if you're running one. (The inverter may also have one built in)
    gsubioguy and johntoyota[QUOTED] like this.
  2. Feb 4, 2019 at 1:26 PM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I didnt know about the one in between the panel and controller. I assumed the controller had this built in.
  3. Feb 4, 2019 at 1:45 PM
    RESQMAN
    Your Renogy 100w panel will make about 5.2 amps in full sun, so a 7.5 amp fuse would be perfect. The most important one is from the controller to the battery. Size it for whatever your controller puts out plus a little over. Like 25A for a 20A controller for example. If the controller fails it most likely will short the battery which is why that breaker is the most important.
    xsf18cdf and johntoyota[QUOTED] like this.
  4. Jun 29, 2019 at 10:24 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I have a 10a fuse between panel and controller per Renogy’s recommendation. And a 30a breaker btwn controller and battery.
    johntoyota[QUOTED] likes this.
  5. Jun 29, 2019 at 10:33 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What type of cinch strap spool is that near your solar panel? Looks great!
  6. Jun 29, 2019 at 10:45 PM
    Rujack
    sd1uh8as and OnHartung'sRoad like this.
  7. Jun 30, 2019 at 5:57 AM
    Ulfr
    Ulfr Well-Known Member
    Tampa, FL
    2019 DCSB 4x4 Manual
    I know you posted this a while back, but did you use an RV solar connector box?
  8. Jun 30, 2019 at 11:52 AM
    Khonception
    Khonception Well-Known Member
    Khon
    Ft worth Tx
    17 DC OR/13 DC/08 DC OR
    johntoyota and Ulfr[QUOTED] like this.
  9. Nov 16, 2020 at 11:21 AM
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
    For you guys that ran wire behind the cab how do you keep the wires clean and concealed without them just dangling down from the roof rack.
  10. May 30, 2023 at 4:49 PM
    brungtruckin
    brungtruckin New Member
    3rd Gen Tacoma SR5
    Centruy camper shell Access cab rear seat delete storage unit
    Popping back in this thread. Anyone tried to do this by feeding the cables through the cab window and using a gasket of some sort to seal it up?
    looking at options to feed some renology wires to a Goal Zero power bank in my cab without having to drill any holes.
    I also did a rear seat delete so could in theory run the cables through some of the holes in the cab behind the seat but would have to remove the storage I built.
    Anyone got strong opinions/pictures of either option?
  11. May 30, 2023 at 5:02 PM
    DevilsPineapple
    DevilsPineapple Well-Known Member
    Richmond
    Voodoo blue 2020 TRD off-road 6MT
    RRW sliders, lil b's hybrid front bumper, Evo 10s, rigid radiance fogs, Agency6 fairlead and flatlink, DRT cmr, SPC uca's, trimmed front fenders, RRW RR7-H 17x8.5 -12 offset, 255/85/17 Micky Thompson baja boss AT, Litner designs forged acs with two xl pods, UpTop Overland Bravo roof rack, rigid radiance series 40" amber backlit led light bar, oem bed lights, c4 inner fender liners, OEM TRD Pro grill, Nitro 5.29 gears, ECGS bushing kit, bilstein 5100s, 2/1.5 lift, old man emu 2888 coil spring, icon add a leaf, long range America fuel tank, OTT tune,
    Maybe something like this and the through the firewall
    https://www.kchilites.com/universal-wire-hider-kc-6300.html
