Where to source OEM lower ball joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Snakeankle, Dec 27, 2024.
  1. Feb 3, 2025 at 2:39 PM
    spazjensen
    spazjensen Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    your're right. And its good, I appreciate the quick response too. Amayama has x2 for about $75. Says OEM from Japan.
    Edit: did not realize the parts submit/request process.... my parts request is pending prior to final payment
    Supr4Lo[QUOTED] likes this.
  2. Feb 4, 2025 at 7:34 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    https://www.ebay.com/itm/352645793021
    this is what I used and it looked exactly like OEM, good fit etc and fixed the problem. Have 1k or so on it so far. I picked this one based on the cost being roughly the same as OEM ones are listed for (around 50-60$ per joint) and then there was expensive shipping from the UAE to be around 25 bucks. In my expirience when buying OEM parts from other sources, if it seems to good to be true (like OEM parts at 30-50% discount) theres a good chance it is because they would have a hard time profitting.
  3. Feb 4, 2025 at 9:39 AM
    Shawner1974
    Shawner1974 Well-Known Member
    Shawn
    CNY
    2012 Base Tacoma 2.7. 5 spd Regular Cab
    Replaced my lowers last year with O'Reilly joints. Beefy and has a good boot on it. Only issue I had was i needed to replace the grease fittings with 90° fittings for access.
  4. Feb 4, 2025 at 4:25 PM
    spazjensen
    Here
    how many miles have you put on them you think?
  5. Feb 4, 2025 at 4:36 PM
    Shawner1974
    Shawn
    CNY
    Coming up on 13000 miles. Just gave them each 2 squirts of grease when I was changing my oil.
