Where to tap in for Trailer Lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whttaco2whl, May 20, 2021.
  1. Jan 6, 2022 at 2:09 PM
    EdableDonut
    EdableDonut Well-Known Member
    Raymond
    09 white Tacoma,
    None. 220k miles, just did a major brake/ suspension overhaul to keep him on the road.
    so I took a few photos it’s a 4 pin:
    Red/white/black/blue (NOTE: in the first photo I have taken out the white end cap)
  2. Jan 6, 2022 at 2:13 PM
    EdableDonut
    Raymond
    09 white Tacoma,
    LArger image sry for noob mistake
  3. Jan 6, 2022 at 4:28 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That connector I believe is for the backup camera which I'm asuming you don't have since its blank.
  4. Jan 6, 2022 at 4:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The connector for the trailer plug if you have it would be on the drivers side and would have 8 pins.
    It looks like the pins are there for the towing tail relay but the relay is not installed, I cant make out anything else.
    Does your truck have DRL?
  5. Jan 6, 2022 at 4:34 PM
    EdableDonut
    Raymond
    09 white Tacoma,
    I looked around and autozone shows a 4 pin
    “Hopkins Electrical Wire Connector 47815 “ that connects to a Hopkins 7pin connector?
    Has anyone tried?
    Edit: NO DRL (day time running lights) they are blanks
  6. Jan 6, 2022 at 4:37 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Thats the adapter harness to install a trailer brake controller, not for lighting.
  7. Jan 6, 2022 at 5:00 PM
    Poison_Dart_
    Poison_Dart_ Member
    2022 Tacoma SR TSS Off-road
    Thanks I was looking in the fuse box a couple days ago for the fog lights and I saw the tow relay and fuse are there so I will have to look under the truck to see if I can dig up the connector you spoke of.
  8. Jul 13, 2022 at 5:00 PM
    Ddiogo
    Ddiogo Member
    Dimitri
    ‘22 Tacoma SR5 Acess Cab
    Is this the one you’re talking of?
    Tacomuncher21 likes this.
  9. Jul 13, 2022 at 8:19 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    That's the one!
  10. Jul 14, 2022 at 3:09 AM
    Ddiogo
    Ddiogo Member
    Dimitri
    So what connector will I need to plug into this? I ordered the oem bumper 7 pin just need a harness to connect the Two
