Where was my tocoma made?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JONNY TACO, Jan 27, 2010.
  1. Jan 27, 2010 at 4:49 PM
    JONNY TACO
    JONNY TACO [OP] Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    Is there any way of telling where my Tacoma was made?
  2. Jan 27, 2010 at 4:51 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    there is a thread on this let me try to find it right quick
  3. Jan 27, 2010 at 4:52 PM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    just look on the sticker on the driver side lower door jamb - next to the tire info sticker.
  4. Jan 27, 2010 at 4:54 PM
    swise
    swise TRIFECTA!!!
    ohio
    The first 2 letters of your VIN also indicate where it was made
  5. Jan 27, 2010 at 4:55 PM
    johnw
    john
    orlando florida
  6. Jan 27, 2010 at 4:57 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
  7. Jan 27, 2010 at 5:09 PM
    JONNY TACO
    PA.
    Someone said if the Vin begins with a 3 it's from Mexico. Anyone know if that is correct ? Mine begins 3TM******
  8. Jan 27, 2010 at 5:11 PM
    TBAGRR
    TBAGRR Well-Known Member
    Md
    07 4x4 sport
    Trd intake Doug Thorley long tubes URD short shifter Eibach front springs Tsb rear leafs
    yup 3=mexico!!!!
  9. Jan 27, 2010 at 5:12 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    BAJA CALIFORNIA, MEXICO!!! Where Toyotas rule as the 4WD small and mid-size truck of choice!
  10. Jan 27, 2010 at 5:15 PM
    JATaco
    JATaco Well-Known Member
    Las Vegas
    tacoma prerunner
    2007 DC OR SR5 Prerunner U.S.A!:D
  11. Jan 27, 2010 at 6:09 PM
    JONNY TACO
    PA.
    Is Baja California considered Mexico or is one in the US and the other obviously Mexico ?
  12. Jan 27, 2010 at 6:48 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    baja mexico is in mexico so it is not part of the US. Ever see pictures of that big fence that runs for thousands of miles along the border. Either country they are made the same buy toyota guidelines
  13. Jan 27, 2010 at 8:00 PM
    LS1Steve
    LS1Steve Well-Known Member
    I've been to the plant... they are assembled in Fremont, CA at the NUMMI facility. The molded composite bed is mfg'd in Mexico.
  14. Jan 27, 2010 at 8:21 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    SOME of them were assembled at NUMMI
    in the future...NONE will be assembled there
    http://en.wikipedia.org/wiki/NUMMI
