Where will the headlight disco fading effect end? I NEED MORE POWER
Discussion in 'Audio & Video' started by inthebed, Oct 28, 2017.
  1. Oct 28, 2017 at 12:15 AM
    inthebed
    inthebed [OP] Well-Known Member
    2010 Tacoma TRD Off-Road Prerunner
    I have a 1700W amp and a 1600W amp. I'm running the amps at 1OHM.
    I have a big 3 upgrade kit on order rated for 350amps.
    Do i need a new alternator? Do I need a second Battery?
  2. Oct 28, 2017 at 8:45 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    If your lights are dimming, you probably need to do something. IME batteries don't last long in that type of setting. You didn't say much about your amps though. Models? What are you using for wiring?
    If your amps really are making 3,300W, then you're overtaxing your electrical (assuming it's stock). At 100% efficiency (impossible) that's 235 amps at 14V. With Class D topology, you might be getting away with as little as 250 amps. That conservative figure is more than your stock electrical can handle. I'm not sure what your alternator is rated for, but I'm pretty sure it's a good bit less than 250A + whatever the truck needs. 3300W usually needs an alternator upgrade and an additional battery to keep up with the current demands.
    nphagert likes this.
  3. Oct 28, 2017 at 6:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Stock heavy duty alternator with the TRD package I believe is 130 amps. Though I don't see how one could actually drive "listening" to 3,300w of music in the truck.
