Where's my oil and transmission cooler located
Discussion in '4th Gen. Tacomas (2024+)' started by Ryguy3684, Aug 3, 2024.
  1. Aug 3, 2024 at 4:03 AM
    Ryguy3684
    Ryguy3684 [OP] Well-Known Member
    Virginia
    2024 Tacoma TRD off road
    My 2008, with 400,000 miles died last week. So, last night I brought home my 2024 TRD off road and I love it. I have the upgraded trailer brake controller and tow package. Where are the transmission & oil cooler located? I can't seem to find it. My 2008 was a small transmission cooler in front of the radiator so it was easy to locate. Any help would be great. I can't find anything online to help. Thanks.
    Gfenza89 likes this.
  2. Aug 3, 2024 at 4:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Those ended sometime during the 3g run IIRC
    So you may not have external units
    Ryguy3684[OP] likes this.
  3. Aug 3, 2024 at 4:33 AM
    Ryguy3684
    Virginia
    I was thinking about that, but the tow package on Toyotas website lists the 2024 as having a transmission & oil cooler. Did they go back to integrating them with the radiator?
  4. Aug 3, 2024 at 4:56 AM
    545 Well-Known Member
    2015 Access Cab
    they’ve had the transmission cooler in the radiator for a long time, they just also used to have the separate one too. They stopped with the additional one on the late 3rd gen’s
    oil cooler has always been a liquid cooler I believe, coolant flows to it
  5. Aug 3, 2024 at 4:58 AM
    Ryguy3684
    Virginia
    Thanks. It's been 16 years with 1 truck, so a lot has changed. Lol. Appreciate the help.
  6. Aug 3, 2024 at 4:59 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    The oil cooler is what the oil filter screws into so look there and you’ll see it. The trans cooler is in the radiator and I believe there is another one under the truck that also uses coolant to cool the trans
    Delta09 and Ryguy3684[OP] like this.
  7. Aug 3, 2024 at 4:53 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Yep, can confirm that my February 2020 OR still had a cooler. Based on 3g posts, those that came later in the year no longer had them.
    There's a whole thread on adding OEM and aftermarket coolers. If you don't tow, I doubt you'll see a noticeable difference with one though. I don't tow and up hills of NY I've seen pan temps in 190s and converter temps in 220s (momentarily on downshifts).
  8. Aug 3, 2024 at 5:19 PM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    If trans heat concerns you, there is a transmission temp gauge (along with water and engine oil) on your dash that you can monitor. Nice feature on the 24's.
  9. Aug 4, 2024 at 10:37 AM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    If it’s like a later 3rd gen Taco like mine, the trans cooler is water-to-oil without the air-to-oil cooler. However, the trans cooler still has a thermostat and a fancier heat exchanger than the typical trans fluid coolers which just run through a small passage of the radiator.
  10. Aug 4, 2024 at 12:07 PM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    The gauge bar will also flash red before the trans temps go full AZ-5 meltdown
