Where's my old woodruff key??????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoson2sdays, Jul 3, 2017.
  1. Jul 17, 2019 at 10:14 PM
    Mr.Purple
    Mr.Purple Member
    Skip
    Texarkana
    1998 Toyota Tacoma 2.4L
    Just found this thread and this exact experience has happened to me this week. My crankshaft bolt was loose fan was hitting Harmonic balancer.. that how I found out about theb olt being loose. And when I got I tightened up the front crankshaft seal blew. Been working and when I was off it was raining. So what ever happened ? Did 6ou get your Taco back on the road?
  2. Jul 18, 2019 at 5:30 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Bummer man, you find that your woodruff key and the keyway in the crank are still okay?
  3. Jul 18, 2019 at 11:34 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    It is really stupid how the key / slot does not go the entire length of the balancer, like every other friggen crankshaft / balancer I have ever seen. I guess it is so the balancer is easy to pull off... But what I want to say is that keeping the front splash pan on at all times, I believe, helps keep salt water from the road out of that area and makes it easier to deal with... It is really hard to get that crank bolt on tight enough, with a manual trans. (in gear and some one standing on the brakes) I can't imagine doing it on an automatic with a holder tool.
  4. Jul 18, 2019 at 12:42 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I do it with the tool by myself the tool can barely hang on the pulley, I have an automatic.. I’m not weak but I ain’t Iron Mike.
  5. Jul 19, 2019 at 7:36 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Even the cat knows that crank should come out. :boom:
