Where's the AC leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by burr64, Jul 10, 2023.
  1. Jul 10, 2023 at 6:51 PM
    burr64
    burr64 [OP] Well-Known Member
    Mechanicsburg, PA
    05 4x4 dblcab sport
    So is there a common place for AC leaks on a 2005?
    I got a recharge with dye but they didn't find any. Worked good for 3 weeks and now is blowing warm again.
    PinkTacomaGirl likes this.
  2. Jul 10, 2023 at 6:58 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did they look at the A/C drain, many times if the evaporator is leaking dye will come out of the drain and also you will get a oil smell when you first turn on the blower.
    Sometimes the compressor seal will leak refrigerant and not bring dye with it.
    I'd get a UV light and look at every part of the system closely for traces of dye.
    Bivouac, burr64[OP] and 6 gearT444E like this.
  3. Jul 18, 2023 at 1:25 AM
    Consurgo
    Consurgo Member
    Ben
    2012 Gray AC BASE Manual / 2017 Brown AC TRD Offroad (for sale)
    none yet!
    Is the smell you mention inside the cabin?
  4. Jul 18, 2023 at 4:03 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    check the high side hose pipe. Its a rubber to metal part that will eventually get leaks where the rubber and metal meet up. Mine developed a tiny leak and i had to replace it.
    if you notice the rubber part coated in grime then its most likely leaking. I cleaned mine off and a week later it was grimey again. A leak test with UV dye confirmed it.
  5. Jul 18, 2023 at 6:19 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes, out of the vents.
  6. Jul 18, 2023 at 10:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lot of possibilities on a older vehicle. Check the service valve schraders, check the condenser for rock damage, look at the compressor shaft seal.
    You're looking for oily residue, near any connections or fittings.
    A 3 week leak is pretty fast, should be leaving some kind of evidence behind for you to find
  7. Jul 18, 2023 at 1:29 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    My 06 leak was a gremlin, too. Needed a recharge every summer, but no trace of visible dye. Shop assumed it was behind the dash by/at the coil.
    Anyways, replaced my AC clutch a couple weeks ago and found some refrigerant oil slightly oozing out the compressor shaft. There's a felt washer behind the clutch magnet and it had green oil. However, now it seems to be holding coolant, but I think it's hit or miss. My compressor is 17 years old and still going.
  8. Jul 18, 2023 at 1:32 PM
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
  9. Jul 18, 2023 at 1:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A spray bottle with soapy water can be sprayed onto fittings and such, look for bubbles
