Where's Waldo? (Where's the oil leak???_
Discussion in '1st Gen. Tacomas (1995-2004)' started by james, Apr 23, 2011.
  1. Apr 23, 2011 at 12:07 AM
    james
    james [OP] In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    Hmmm...I smell the unmistakable smell of oil after I stop. I don't know why. Clearly I'm leaking some oil somewhere.
    I changed my oil about 1000 miles ago (give or take a month ago), and that's when I began smelling it. I checked the tightness of the filter and it's plenty tight.
    '98 3.4 manual. 158K miles. I recently changed out all my fluids, including transfer case and gearbox to synthetics. Could they be dripping? If a drop or two hit the exhaust pipe, it would make that unmistakable smell too, right?
    Where would you start looking first?
  2. Apr 23, 2011 at 6:22 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Do what ^^^ he said and then park on a piece of cardboard till the leak is detected on the cardboard and see if you can nail it down from there.
  3. Apr 23, 2011 at 6:41 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Baby powder works great for finding leaks also. Clean the whole engine with a good degreaser and than dust around the areas where it could possibly be leaking.
  4. Apr 23, 2011 at 8:29 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Switching to synthetic might be causing a weep somewhere in your engine. Happens a lot when high mileage engines switch. I would personally give it time, as long as you have enough oil in the engine I would keep driving it and see if it gets better.
  5. Apr 23, 2011 at 4:20 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    As for your question about the exhaust... yes. Especially a cat. If you got a little oil on anything it'll burn. I once got a plastic bag caught between a cat and its heat shield and thought my clutch was burnt up for about a week until I found it.
  6. Apr 23, 2011 at 4:24 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    valve cover gaskets, oil pan, rear main, front crank, cam seals.... all are common...
