Which 15x8 wheels, and tires for stock 1st gen?
Discussion in 'Wheels & Tires' started by 01Stepside, Nov 3, 2011.
  1. Nov 3, 2011 at 9:50 PM
    01Stepside
    01Stepside [OP] New Member
    Elgin, SC
    2001 2.7L, Stepside SR5, 4x4
    Tinted Windows
    searched around and have not found anything definite which is why I am posting :)
    I have a stock 2001 Tacoma 4x4 and I need new tires soon and hate my wheels as well, so I figured id get both.
    Im looking for some black wheels..etc such as the wheelers or cragar soft 8s or something comparable in 15x8, unless you suggest another size and need to know what options are out there and will fit with the least amount of trouble.
    I also would like to know what is the biggest tire i could run on the wheels you suggest. I am aware that most would recommend getting a lift which would allow for bigger tires but that's not in my budget at the moment and I like the truck at stock height for now.
    Thanks
  2. Nov 3, 2011 at 10:01 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    im not sure if the 15's will fit on an 01. i could be wrong. but i think they have to be 16's to clear the caliper. and without lift about the largest tire you could fit would be a 265/75/15 or 16 whichever.
  3. Nov 3, 2011 at 10:01 PM
    Wolfrunner
    Wolfrunner Well-Known Member
    Graham, WA
    '04 Tacoma Double Cab SR5
    Grey wire mod, 17" tundra wheels powder coated
    31/ 10.50R 15 should be a good size.those wheels you listed were all steel wheels. is that what your looking for? steel is cheaper than aluminum wheels. you might be able to fit a 32 1150 15 but I wouldnt suggest it unless you want to do some trimming. just watch out for tire rub on the upper control arm. I personally like factory wheels that have been painted or powdercoated.
  4. Nov 3, 2011 at 10:03 PM
    98_Mud_bug
    lucedale Ms.
    32's will fit with out any trimming. thats the factory size on the trd offroad trucks. it equates out to a 265 75 15
  5. Nov 3, 2011 at 10:06 PM
    98_Mud_bug
    lucedale Ms.
    i stand corrected then, my apologies.
  6. Nov 3, 2011 at 10:06 PM
    98_Mud_bug
    lucedale Ms.
    its been a while since i had factory tires on mine. when i bought mine it had the stock 225/70/15's on it.
  7. Nov 3, 2011 at 10:13 PM
    Wolfrunner
    Graham, WA
    the 265 75 16 isnt a 32" tall tire. depending on the tread design its is around a 31.2-31.5. A 32 in a 15" wheel is right at 32". but like I said it all depends on the tread and how deep it is. Trust me on this one. I sell tires for a living.
  8. Nov 3, 2011 at 10:18 PM
    98_Mud_bug
    lucedale Ms.
    i used to, but that was about 5 or 6 years ago..
  9. Nov 3, 2011 at 10:28 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you can fit 15s up to 2004...
    you likely will not clear the brake vein with Soft 8 style steel wheels... the dimple dies stick in too far...
    if you use a small spacer, you could run the 8s...
  10. Nov 3, 2011 at 10:31 PM
    01Stepside
    Elgin, SC
    Tinted Windows
    Thanks for the replies , and yes black steel wheels are primarily what I am looking for :) I had read that wheelers 15x8 would fit an 1 gen, and the second gens only needed 16 or bigger, I could be wrong though .
  11. Nov 3, 2011 at 10:48 PM
    Wolfrunner
    Graham, WA
    we sell Allied wheels at my work and they dont work on the tacoma's cause like mikesdoublecab said they rub on the calipers. I never recommend spacers due to the fact that they move the wheel away from the hub which puts more stress on the wheel studs and your more likely to have a loose wheel. Good thing about going into a shop is they can test fit and find out what works and what doesnt. Just my 2 cents and what I have seen over the last 8 years of working at a tire store.
  12. Nov 3, 2011 at 10:53 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    although, i do like Allied Wheels cuz i did run their black steel streetlocks with the D windows for 3 years and i was able to order them in 4" backspace when nobody else at the time was offering that style of wheel in anything less than 4.25"
    a great solid wheel...
