Which 1st gen frames would fit my truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by K-Dawg, Sep 8, 2021.
  1. Sep 8, 2021 at 1:50 AM
    K-Dawg
    K-Dawg [OP] Member
    2000 Toyota Tacoma XTRA Cab
    If I have a 1st gen Ext cab 4x4 6cyl, would any 1st gen extended frame (2wd, 4cyl, etc.) fit my truck? Or do I need to find the exact same trim level to be compatible.
    Also, can someone explain the difference between a pre-runner and a Tacoma? Can I use pre-runner parts on my truck?
    thanks,
    Newbie
  2. Sep 8, 2021 at 1:58 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    If you have a 5 lug truck you need a 5 lug frame, if you have a six lug truck you need a 6 lug frame.
    Similarly if you have an auto you need an auto, a manual needs a manual.
    And a 4wd needs a 4wd.
    As you decerned it has to have the same cab as well.
    But so long as those are the same anything trim level won't matter, trim is largely just feature packages but not mechanical differences.
    A "Pre-Runner" is just a 2WD TRD Off-Road, some came with the optioned rear locker.
    Most parts manufacturers use Pre-Runner as a base 6 luck truck to differentiate from a base Tacoma which is 5 lug.
    Pre-Runner parts will for the most part work on your truck so long as you have a 6 lug.
    There's some exceptions to this information (for instance the very rare factory 5 lug V6's) but it should be fairly accurate for most situations, it is of course always best to double check for your specific instance.
  3. Sep 8, 2021 at 7:25 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    1996 thru 2004 ext cab 6 lug frames will work.
  4. Sep 8, 2021 at 9:13 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You definitely need to keep it in the 5-lug/6-lug family, but as far as needing a 4x4 frame (if you're a 4x4) I'm not so sure about that. 1st gen pre-runner to 4x4 conversions are all bolt on, so the frames are identical.
    If you want to make it "easy", yes, find an identical frame from an identical model, v6, auto, etc... That said, just about any 6-lug xtracab frame will work.
  5. Sep 8, 2021 at 9:20 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It really comes down to how you define fit
    They would all fit some just need much more work to make it happen.
    Don`t forget to factor in shipping costs from the dry rust free part of the country
  6. Sep 9, 2021 at 4:47 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    It needs to be an excab frame, prerunner or 4x4 no 5 lug. Auto or manual doesn’t matter. 98-04 preferably, 95.5 will work but Leaf springs are shorter. Engine mounts are 1 inch farther forward on a 3.4 vs 4cyl but are the same and easy enough to move.
    Dan496 likes this.
