Which 2011 models have daytime running lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Meadow2019, Aug 17, 2020.
  1. Aug 17, 2020 at 8:10 PM
    Meadow2019
    Meadow2019 [OP] Member
    2011 Red Tacoma 4x4
    I've got a 2011 V6 SR5 and the only lights that come on when I turn the headlight knob forward one "notch" are the tiny marker lights. The turn signal lights only work as turn signals. The manual says "if equipped" when I look for daytime running lights. I think that some models have turn signals that also function as daytime running lights, but I'm not sure. (I noticed this when I took the truck to a drive-in movie and could hardly see without turning on the headlights.) I guess I'm wondering if everything is functioning as normal with just the marker lights, or if I should be checking to see why the other lights don't come on before I get to the headlight setting. Thanks for any help.
  2. Aug 17, 2020 at 10:09 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    I have a ‘11 TRD Sport and it has the DTRL. Not sure if specific trims always had it tho.
    also, the DTRL’s are on even without the headlight stalk clicked once. It’s default for me.
  3. Aug 17, 2020 at 10:48 PM
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
    Daytime Running Lights (DRL) is a factory installed option in response to the vehicle build / order sheet
    See attached 2011 Tacoma Sales Brochure, Safety and Convenience section (about page 15). :bananadance:
    For 2011 Tacomas, it appears DRL ON is the default condition, at least before parking or head lights are selected.
  4. Aug 18, 2020 at 2:13 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    FYI
    The default DRLs do not come on at startup if you are looking then. Must be put in gear then they flip on. Back in park they stay on until vehicle turned off or you turn the headlights on then they go off (back on when you turn headlights off). Same bulb as turn signals in front.
    TRDSport10 likes this.
  5. Aug 18, 2020 at 3:11 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    my DRL’s come on when I turn the truck on.
    I think you’re mistaken this. I know they don’t turn on with the parking brake on though. But some people don’t use the parking brake
    Spizike231 likes this.
  6. Aug 18, 2020 at 3:37 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    The DRL’s on my 2011 truck are on when the truck is running, no action necessary, other than starting the engine. I agree with you @Tcomaboy .
    TexasWhiteIce[QUOTED] likes this.
  7. Aug 18, 2020 at 3:43 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    ^^ This ^^
  8. Aug 18, 2020 at 5:44 PM
    Meadow2019
    2011 Red Tacoma 4x4
    Thanks for the answers. I guess mine just work as turn signals.
  9. Aug 18, 2020 at 7:15 PM
    Spizike231
    Jesse
    Sacramento, CA
    You could do some reverse searching. I think a few guys enjoyed turning them off as DTRL’s and just used them as turn signals. If it’s as simple as moving a fuse or a few wires to re arrange, you could reverse it if someone did it.
  10. Aug 18, 2020 at 8:03 PM
    vtdog
    vtdog Well-Known Member
    NH
    I believe there is a plug in module which is sold in Canada which converts the headlights to DRL as it is required there
  11. Aug 18, 2020 at 8:06 PM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    2011 Base Access cab, manual...added the DTRL, per spec. Come on only when I put it in gear.
  12. Aug 18, 2020 at 10:50 PM
    caribe makaira
    Caribbean, Puerto Rico
    You could have a failed DTRL relay or the ground to activate has been severed.
