Which 2014 to buy to build?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drrandall1, Jul 23, 2014.
  1. Jul 24, 2014 at 11:29 AM
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    The front end is Totally worthless for offroad. its a clamshell. Any serious offroading will deflect it and eat the gears.
    The SR5 is the 8.4" ring gear rear. Tacoma Fanboys/offroad noobs will like to say the 8 to 8.4" makes no difference but it does. It makes a big difference.
    Honestly for the work I'd go with the rubi.
  2. Jul 24, 2014 at 2:20 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    The front end of a Tacoma is not worthless for moderate wheeling. You can swap in a solid axle in the front to do hardcore stuff but you will need to have some deep pockets or have the fab skills to do it yourself.
    There are a dozen or do solid axle 05+ Tacoma trucks running around. Some are garbage and some are works of art. I only know of two that are done well enough to be drivable enough to be daily driven.
    What is your intended use for your truck. DD and weekend toy? Full trail rig with occasional trips on the street or?
  3. Jul 24, 2014 at 2:26 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    How many 05+ Tacomas have you built? Or is it just in your experience from what you've read online?
    If you throttle down on a Rubi with a D44 hard enough with 35" tires you can grenade the rear end of it. The same is true with the 8.0" TRD E-locker or the 8.4" rear end.
    I would agree with you that the aftermarket support to build a Rubi is better and that a D60 front and rear will eliminate your problems. But a D60 front and rear would allow you the same thing with a Tacoma.
  4. Jul 24, 2014 at 4:06 PM
    Drrandall1
    Drrandall1 [OP] Member
    Derek
    Westminster, Co
    Not sure
    Lots coming
    It will be my daily driver and off roading on my days off.
  5. Jul 24, 2014 at 4:09 PM
    Drrandall1
    Derek
    Westminster, Co
    Not sure
    Lots coming
    Guess when it's all said and done it will probably cost just as much to build a Tacoma to get it close to a Rubicon. Bummer.
