Which A R Rims ATX Series Artillery Teflon do I need??
Discussion in 'Wheels & Tires' started by Eesh, Feb 10, 2010.
  1. Feb 10, 2010 at 1:27 PM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    Can someone help me out here... I'm looking at getting American racing ATX Series Artillery Teflon Black rims. I have a 3 inch lift. And I know I want 17x9 but what bold pattern do I need? These are the 3 options on their site... I also don't know what the difference between the first and last option is other than the code.
    AX18179060612N 17" x 9"-124.53 6x139.7
    AX18179068612N 17" x 9"-124.53 6x139.7
  2. Feb 10, 2010 at 2:30 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You need the 6 x 139.7 bolt pattern, which the first and third option have. Not sure about the difference between the two part numbers.
  3. Feb 10, 2010 at 2:32 PM
    weiser5150
    weiser5150 Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    go to wheelpros.com and look at their applications.
  4. Feb 10, 2010 at 3:28 PM
    Eesh
    Canada
    2025 Tacoma Limited
    After much searching I ended up calling wheel pros 1800 number they told me that the different part numbers were do to different hub sizes. This is the part number that fits tacoma.
    AX18179060612N
  5. Feb 10, 2010 at 7:35 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    One is probably hub-centric and the other lug-centric. You want lug-centric
    Edit: I'm way behind:mad:
  6. May 27, 2010 at 11:22 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    I am waiting for my ATX Artillerys to come in a day or two, I actually had the same problem....I went with the other rims....106.25mm. I spoke with the American Racing company and Toyota and it sounds like the 106mm is the correct hub size. Whether the website fitment guide is incorrect or not, I don't have a clue. You can also use the 108mm, but you need an adapter to take up the space. If anyone is getting new vibrations or noise after there new lift and rims, might want to check their wheel fitment! Here is a link to my origianal post asking this question.
    http://www.tacomaworld.com/forum/wheels-tires/94317-correct-hub-bore-diameter.html
