Which AAL do i get?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbybreach, Nov 2, 2015.
  1. Nov 2, 2015 at 5:00 AM
    bobbybreach
    bobbybreach [OP] Well-Known Member
    bobby
    westchester NY
    09 TRD
    i want 1.5'' to 2'' of lift in the rear. im reading that the LONG toytec AAL is best for a better ride. does it add payload capacity or is it mostly for looks?
    the SHORT toytec AAL says its a harder ride. is it really harsh? will the SHORT AAL work with my factory overload leaf? will it add payload capacity?
    I don't haul much but when I do its either a 17' boat, lumber, or firewood. my taco is also my everyday driver.
    also should I upgrade my rear shocks to billys as well or leave to stock shocks on?
    the front I plan on getting OME 885 springs (1.75") with billy 5100s set at .85"
  2. Nov 2, 2015 at 7:09 AM
    ACKtrd30
    ACKtrd30 Nice Guys don't finish last. Boring guys do.
    Massachusetts
    2016 Desert Storm Trooper
    If you're worried about weight, i'd look into a full leaf pack. OME Dakars are affordable. I carry a ton of weight and tow a boat, and they don't sag much at all. In past experience, AAL doesn't help much for weight. Ride quality is a little more stiff with a full on leaf pack when you're not carrying much as you'd imagine, but in my case it's worth it. When I get a minite I'll post two pictures of my truck loaded with ~600lbs and a topper, as well as unloaded to show you how well of a job the Dakars do.
